What would you change
Changes
40 members have voted
1. Which of these would you want (or have) to give up or change?
Retractable gear to fixed gear (with similar speed)3
Constant speed prop to automatic rpm control6
Mixture control to automatic mixture control12
Steam gauges to glass panel17
Manual course control to GPSS8
Manual approaches to coupled approaches7
Manual flying to auto pilot9
Paper charts to electronic flight bag14
ADF to VOR6
VOR to GPS8
GPS to GPS WAAS14
Wet wing to bladders6
Normally aspirated to turbo10
Single engine to multi-engine1
Normal to experimental category5
Normal to utility or aerobatic category2
Single to two door17
Aluminum to composite1
Avgas to diesel15
Steel roll cage to ballistic chute4
2. Which do you intentionally NOT want to change
Retractable gear to fixed gear (with similar speed)26
Constant speed prop to automatic rpm control12
Mixture control to automatic mixture control9
Steam gauges to glass panel4
Manual course control to GPSS0
Manual approaches to coupled approaches1
Manual flying to auto pilot4
Paper charts to electronic flight bag0
ADF to VOR1
VOR to GPS0
GPS to GPS WAAS0
Wet wing to bladders10
Normally aspirated to turbo6
Single engine to multi-engine14
Normal to experimental category11
Normal to utility or aerobatic category11
Single to two door1
Aluminum to composite9
Avgas to diesel5
Steel roll cage to ballistic chute8
