This should be easy... Can someone tell me what this placard said when it was readable? I want to replace it - cosmetic work...
post-8421-0-31238500-1378177260_thumb.jp
I forgot to mention - 66 E model.
Load in accordance with loading schedule maximum baggage allowance 120 pounds
Looks like...
"Load in compliance with loading schedule.
Maximum baggage allowable - 120 lbs."
Do you have the loading schedule from the POH or AFM?
That is for the baggage area below and in front of the decal. There may be another for the hat rack. Something about 20 pounds soft fuzzy articles only.
My '76 C POH does not indicate what the decals actually say on them like newer POHs may for newer airplanes...
Hope that helps.
The "hat rack" =
"Warning: Do not Exceed 10 Pounds in This Compartment. See Aircraft Loading Schedule Data for Baggage Compartment Allowable."
I can't find a pic of my engraved rigid plastic placard big enough to read. I'll take one and post later.
post-8913-0-25969800-1378212865_thumb.jp
The "hat rack" =
I noticed "Data" was changed to "Date" but you get the idea.
post-8913-0-67072400-1378223307_thumb.jp
