ighazali Posted Sunday at 03:38 AM Report Posted Sunday at 03:38 AM Hey everyone not sure if this is concerning. My current oil consumption is about .13qt per hour so essentially 1 quart every 7.6 hrs. Today when looking through the cowl flap door where the breather tube and blowout valve is I saw some oil on an intake pipe. Any ideas if the O-ring may need to be replaced. Oil pressure and consumption seem to be okay. Oil analysis also came back stating a healthy engine.
N201MKTurbo Posted Sunday at 04:31 AM Report Posted Sunday at 04:31 AM Most likely running down from above. There is no oil behind the O-rings. 2
ighazali Posted Sunday at 06:05 AM Author Report Posted Sunday at 06:05 AM 1 hour ago, N201MKTurbo said: Most likely running down from above. There is no oil behind the O-rings. Thanks! So nothing to be concerned? Also is the oil burn normal?
LANCECASPER Posted Sunday at 11:22 AM Report Posted Sunday at 11:22 AM 7 hours ago, ighazali said: Hey everyone not sure if this is concerning. My current oil consumption is about .13qt per hour so essentially 1 quart every 7.6 hrs. Today when looking through the cowl flap door where the breather tube and blowout valve is I saw some oil on an intake pipe. Any ideas if the O-ring may need to be replaced. Oil pressure and consumption seem to be okay. Oil analysis also came back stating a healthy engine. When you say "new engine" is this a factory overhaul or re-man, an engine specialty shop overhaul or a field overhaul?
Aaviationist Posted Sunday at 11:29 AM Report Posted Sunday at 11:29 AM Also the fact that that it can’t be coming from the intake doesn’t mean “nothing to be concerned about” you need to find where it’s coming g from to make that determination. 1
skykrawler Posted Sunday at 12:06 PM Report Posted Sunday at 12:06 PM New engine? I guess those are Teflon hoses (replace on condition), otherwise they look kind of oldish. Sources of oil from 'up above' include the rocker box gaskets, rocker box drain B nut connections, intake manifold gaskets, push-rod tube seals, and even exhaust flanges. Engines that 'pool oil' in the cylinder at shutdown can leak it at the intake and exhaust stack connections. One mode of this is oil coming down the valve stems. The #2 intake runner is most susceptible to chewing it's gasket due to it's length. If it doesn't leak out the flange it will likely end up in the induction chamber where the four intake runner connect. The next time you flood the engine some oil will wash out the sniffle valve. But....what you're seeing is a relatively small amount of oil compared to a quart. IMHO. 1
N201MKTurbo Posted Sunday at 12:58 PM Report Posted Sunday at 12:58 PM 6 hours ago, ighazali said: Thanks! So nothing to be concerned? Also is the oil burn normal? It doesn’t sound like you are going to run out of oil, but it should be fixed, if for no other reason, so your airplane doesn’t look too ghetto. 1
Flyler Posted Sunday at 03:20 PM Report Posted Sunday at 03:20 PM Lycoming says allowable oil consumption is up to about .65qt per hour for your motor. So you are far from that. 1
Ragsf15e Posted Sunday at 04:01 PM Report Posted Sunday at 04:01 PM So to “Carusum” (summarize), 1 qt in 7 hours is just fine but you should look into it because something isn’t right and it won’t get better by itself. It’s probably not urgent. 1
cliffy Posted Sunday at 04:12 PM Report Posted Sunday at 04:12 PM I hate oil leaks! I want my engine to rust away from the outside not be preserved in a bath of oil! :-) My guess is the rocker cover drain tubes hose couplings above. Just found my prop governor cap leaking on last trip so off it comes next week in annual. Antique airplanes take constant maintenance just like old Rolls Royces !! :-) Don't fall behind on the job. 1
ighazali Posted Sunday at 06:21 PM Author Report Posted Sunday at 06:21 PM 6 hours ago, LANCECASPER said: When you say "new engine" is this a factory overhaul or re-man, an engine specialty shop overhaul or a field overhaul? It is factory overhaul was done back in 2023 only has about 100 hours on it 1
Jsno Posted Sunday at 08:55 PM Report Posted Sunday at 08:55 PM Your oil return line clamps probably need tightened. 1
