druidjaidan Posted September 22 Report Posted September 22 (edited) No sooner do I get the broken through bolt replaced and another random thing breaks. I got the broken through bolt replaced this weekend (see other thread for that), did a nice long run up and then flew near the airport for a bit before finally heading out on a short flight to a nearby field for lunch. Everything was going perfect, engine working great. Feeling pretty confident that the through bolt failure didn't have any latent issues. Then I head back from lunch. A couple minutes after departing my EDM 900's tach display starts oscillating wildly. At first I'm a bit panicked, did something go wrong? However, nothing sounded or felt wrong. If my RPM was acting as crazy as the instrument it would have been obvious. So I landed and....the RPM started working. Pulled the cowl an started looking for the RPM sensor. Found the cord and traced it forward...and realized it was just completely snapped off. It must have just been touching, and just the air through the cowl was making it move around and sometimes make contact. I'm having trouble trying to figure out what actually will need to be replaced and I like to know that before I call in the mechanic. Since the part number 420807 on the wire is the pressurized mag part to me it looks like someone cut the end off a pressurized mag JPI sensor (I don't have pressurized mags afaik either so not sure why that part) and then crimped another wire onto the end? This doesn't really look like https://www.aircraftspruce.com/pages/in/probesandsenders_zjpi/jpi10-05459-61.php. Sorry, It's a little hard to tell what's going on in these photos, but I'm holding the broken off spiced wire. I had trouble finding where exactly it broke off of tbh. I'm assuming one of my mag will have the end of the sensor in it. Edited September 22 by druidjaidan
EricJ Posted September 22 Report Posted September 22 Glad you got the motor stuff sorted out. Do you still have a mechanical tach, too, or just the JPI?
PT20J Posted September 22 Report Posted September 22 Here's the page for the JPI sensors. https://www.jpinstruments.com/shop/rpm-sensor-for-bendix-mag/ I would confirm what mag you have and then call JPI to confirm the correct rpm sensor part number. If you don't have the correct part, I'd get the correct one. If your part is correct, I'd just splice the wiring either by re-pinning the Molex connector if there is enough cable or using butt splices if not. 1
rklems Posted September 22 Report Posted September 22 That picture sure looks like a pressurized mag to me? Isn't that a hose going in to the mag right there? So the 420807 sensor mounts underneath the calibrated leak orifice plug on the magneto. Most of the pictures that you'll see online linked to the 420807 are the wrong picture... It's more like a washer with a lead. I'll attach a picture below. It would likely be a pain to pull the orifice and change the sensor with the mag in place, though depending on the clocking of the mag, it might be possible.
druidjaidan Posted September 22 Author Report Posted September 22 (edited) I suspect I'm going to find something very rigged, considering the whole thing I'm holding is a set of butt splices. I looked in my logs and the mag is 10-79020-18, the unpressurized mag it looks like. I suspect the wiring is all the same it's just sensor end that's different. I suspect that for whatever reason when they where installing the EDM they ordered the wrong sensor, then cut off the end and wired it up to an existing sensor from whatever was in there before I guess. I need to get back to the plane for a better look to be sure, I didn't know what I was looking for yesterday when I had it apart. I suspect I'll find something loose from the sensor, might just end up ordering a new one to clean this up instead of adding yet another butt splice. Edited September 22 by druidjaidan
druidjaidan Posted September 22 Author Report Posted September 22 I'm going to check again on the mag. I don't see them being replaced in the logs with a pressurized version, and my engine is a GB from 79 so I don't think it was changed over to pressurized mags. But that sure does look like a hose going into the mag now that you point it out And that sensor looks a lot what my wire and I saw something on the mag that looked like I imagine that does under the shrink tube. Maybe it just pulled out? I'd expect that to be crimped in I guess.
rklems Posted September 22 Report Posted September 22 16 minutes ago, druidjaidan said: I suspect I'm going to find something very rigged, considering the whole thing I'm holding is a set of butt splices. I looked in my logs and the mag is 10-79020-18, the unpressurized mag it looks like. I'd definitely take a look at the data tag on the mag. The 10-79020-18 is an S6LN-25, which is an S-20 magneto, not an S-1200 mag (which is what the 420807 sensor is for). So that would definitely be the wrong sensor if that's the mag you have. If you have a pressurized S-20 series magneto, the 420806 is the proper PN per the 930 installation manual "For the pressurized Bendix -20, 200, series & S6LSC-25P and non-pressurized Slick 600 use JPI P/N 420806." There isn't enough in the picture to positively identify the mag for me, but it being unpainted, feels like an older style mag.
LANCECASPER Posted September 22 Report Posted September 22 I would have thought any unpressurized mags on early 231s would have been changed out by now. That engine needs pressurized mags.
druidjaidan Posted September 22 Author Report Posted September 22 (edited) 1 hour ago, LANCECASPER said: I would have thought any unpressurized mags on early 231s would have been changed out by now. That engine needs pressurized mags. Going to go look again today, I might have missed it being changed over and just didn't check. I didn't find it in the logs, but that image sure looks like I'm wrong. It also makes me even less inclined to overhaul anytime soon. My records still indicate this is a GB engine, but maybe this has had more of the LB conversion than I thought. Edited September 22 by druidjaidan
druidjaidan Posted September 23 Author Report Posted September 23 Not sure what to make of the mag. That line running to the mags definitely looks to be a pressurization line, but the dataplate says it's a 10-79020-18 and not a 10-79020-118 (which as far as I can tell is the pressurized version). I'll have to poke my mechanic to see if he can explain it. That said, the picture of the actual sensor resolved the whole thing, thanks @rklems. I had seen a strange metal tab sticking out of the mag, but didn't connect that it was sensor connection since it looked nothing like the images online. Once I saw that it was really clear what had happened. The only thing holding that together is the rubber sleeve and the bulge on the end. Someone had decided to pull it out instead of cutting the ziptie and disconnecting the molex during a recent maintenance. That particular mag was just replaced after the previous one failed, and two days later the alternator failed. Either of which I could see having the mechanic needing to pull that out of the way. When the put it back they didn't push it all the way down (like in the image) and likely just pushed the head in. That worked it's way out after 10ish hours of flying. Either way it's reattached now and everything is good to go.
rklems Posted September 23 Report Posted September 23 16 hours ago, druidjaidan said: Not sure what to make of the mag. That line running to the mags definitely looks to be a pressurization line, but the dataplate says it's a 10-79020-18 and not a 10-79020-118 (which as far as I can tell is the pressurized version). I'll have to poke my mechanic to see if he can explain it. From a comparison of the parts list in table 11-5 of the S-20/S-200 service support manual, the -18 and -118 are essentially identical parts lists, except the -118 has the orifice instead of a vent plug(#44a vs #44), as well as 3 additional gaskets (#14, 34 & 49 in the parts drawing). So it's possible someone "converted" that to a pressurized mag without updating the data plate. At the end of the day, glad you got it working again, but technically, the sensor is not the one they are calling for to be used with that magneto (though appears to be working fine when it's plugged in), and you may want to be sure the magneto was properly converted between the -18 and -118 (if it was really converted, they should have changed the data plate)... in the pictures it doesn't look to me like the gaskets are present (they are a rubberish+metallic and you can usually see the edges of the metal fibers sticking out), but again, hard to tell. They may have just put the fittings on the mag to feed the upper deck pressure, I'd also be curious if the proper calibrated leak orifice is installed instead of the vented plug where the sensor is.
EricJ Posted September 23 Report Posted September 23 10 minutes ago, rklems said: From a comparison of the parts list in table 11-5 of the S-20/S-200 service support manual, the -18 and -118 are essentially identical parts lists, except the -118 has the orifice instead of a vent plug(#44a vs #44), as well as 3 additional gaskets (#14, 34 & 49 in the parts drawing). So it's possible someone "converted" that to a pressurized mag without updating the data plate. I was gonna suggest that as well, that it just looked like a poor-man's pressurization mod to a regular mag. Somebody may have been taking some high altitude trips and had some ignition hiccups and just decided to solve it that way.
