jamesm Posted May 14, 2025 Report Posted May 14, 2025 I am having a discussion with another A&P & IA about hoses. Had fuel pressure line from carburetor to fuel pressure transducer on the engine monitor CGR30 which is -2 diameter hose. it a -2 at carb and it's a -2 at the pressure transducer. the hose started spraying to confirm it really was the hose, we removed it plugged one end and blew air soapy water and watched the soap bubble. I have been down road a gazillion times but found no real definitive answer. both the manifold pressure line and fuel pressure line off the carburetor has -2 fittings. problem is that the so called fuel rated hose material doesn't really start until you get to -3 diameter and larger diameters. If you use Aluminum line it work hardens I have happen to me twice. IMHO it would be stupid to run fuel through in such a small of diameter which would break frequent . I suppose you put couplers and reducers and enlargers and you would have about 1/2 foot of fittings pron to leak. Maybe it's done out in field but I would suspect I would seen it all people 's pictures of their plane photos. If I look at Parker page the 193 hose is for vacuum and air on Mcfarlane web site. I have found plenty of Hose material compatible of supporting Fuel and Oil by haven't found one that supports that is -2 diameter hose diameter. . What Guidance do I have or where would I go to find -2 diameter hose material that supports "Fuel". Please advise, James '67C
N201MKTurbo Posted May 14, 2025 Report Posted May 14, 2025 Call a hose shop. If you look in the Stratoflex catalog, it shows all the different hose/fitting combinations. 1
jamesm Posted May 14, 2025 Author Report Posted May 14, 2025 I can't find it for such a small diameter.
jamesm Posted May 14, 2025 Author Report Posted May 14, 2025 Here is what I found… https://aircrafthosestore.com/pages/how-to-choose-an-aircraft-hose as expected no -2 hose are made for fuel pressure line from carburetor to fuel pressure gauge. I tried to find it in the Mooney maintenance manual and IPC. No luck
N201MKTurbo Posted May 14, 2025 Report Posted May 14, 2025 28 minutes ago, jamesm said: Here is what I found… https://aircrafthosestore.com/pages/how-to-choose-an-aircraft-hose as expected no -2 hose are made for fuel pressure line from carburetor to fuel pressure gauge. I tried to find it in the Mooney maintenance manual and IPC. No luck That is a tiny fraction of what’s in the Stratoflex catalog.
Fly Boomer Posted May 14, 2025 Report Posted May 14, 2025 12 hours ago, jamesm said: I can't find it for such a small diameter. According to the Statoflex catalog, 124-3 is about a quarter-inch OD. Yours is smaller?
jamesm Posted May 14, 2025 Author Report Posted May 14, 2025 Yes if I recall correctly that the original fuel pressure/ manifold pressure gauge, used a -2 fittings on gauge and the firewall fittings to respective sources. The manifold pressure gauge used an aluminum line (right/ wrong or indifferent) at least since the time the plane has been in the family since 1984.
Gee Bee Aeroproducts Posted May 14, 2025 Report Posted May 14, 2025 (edited) Milh5593 is not approved for fuel and oil . I suggest and I have designed a female -2 to step -3 flare adapter for firewall Then change fitting on carb to alloy -3 Next , I build tso Teflon hose -3 to your spec. Firesleeve Black or Blue I designed this for 1947 to 1971 Beechcraft models -2 oil psi Fuel Psi manifold psi I have been designing hoses and adapters tso since 1987. Iam the only tso PT6 hose supplier for aftermarket. i dont do anything based on cost only quality. last picture is tio541 20 hose assys 4775.00 i have to mfg the prop accumaltors next week . these are engine not airframe to engine Edited May 14, 2025 by Gee Bee Aeroproducts
N201MKTurbo Posted May 14, 2025 Report Posted May 14, 2025 https://www.parker.com/us/en/divisions/stratoflex-products-division.html https://aircrafthosestore.com/pages/current-catalogs
Gee Bee Aeroproducts Posted May 14, 2025 Report Posted May 14, 2025 Just a follow up I can mfg a tso -2 Teflon , but the fittings are expensive, changing to -3 is half the cost . Iam doing a -3 fuel vent tomorrow Gauge to firewall Firewall to baffle This is in case of fuel gauge failure and fuel goes overboard. cost is 477.50 with anti chafe .
jamesm Posted May 15, 2025 Author Report Posted May 15, 2025 (edited) How do I deal with fitting coming off the carburetor for fuel pressure line? it's a -2 flare 90 degree looks to be a aluminum ( blue) fitting. The current installation doesn't go through the firewall. it has a ~ 25" long -2 hose going into an EI CGR30C/P pressure transducer which of course has a male fitting to a -2 hose flare fitting. mounted on one of Engine mount tubes. Can the carburetor fitting be aluminum? same with the EI transducer should be steel or aluminum or ??? Thanks for all the input. James '67C Edited May 15, 2025 by jamesm
Gee Bee Aeroproducts Posted May 15, 2025 Report Posted May 15, 2025 I stock 45 and 90 elbow -3 adapters If you don't understand, consult your mechanic.
Gee Bee Aeroproducts Posted May 15, 2025 Report Posted May 15, 2025 2 hours ago, jamesm said: How do I deal with fitting coming off the carburetor for fuel pressure line? it's a -2 flare 90 degree looks to be a aluminum ( blue) fitting. The current installation doesn't go through the firewall. it has a ~ 25" long -2 hose going into an EI CGR30C/P pressure transducer which of course has a male fitting to a -2 hose flare fitting. mounted on one of Engine mount tubes. Can the carburetor fitting be aluminum? same with the EI transducer should be steel or aluminum or ??? Thanks for all the input. James '67C The adapter screws on the -2 bulkhead fitting to convert to -3 hose Assy
Kelpro999 Posted May 16, 2025 Report Posted May 16, 2025 193-2 is listed in Mooney parts manual. -2 is easy to assemble, light weight and meets minimum bend radius requirements for easy install. Hose specifications has me concerned also so it’s on a replacement schedule.
Gee Bee Aeroproducts Posted May 16, 2025 Report Posted May 16, 2025 4 minutes ago, Kelpro999 said: 193-2 is listed in Mooney parts manual. -2 is easy to assemble, light weight and meets minimum bend radius requirements for easy install. Hose specifications has me concerned also so it’s on a replacement schedule. Read the mil spec 193-2 306-2 milh5593 not for fuel and oil Safety is inexpensive.
Kelpro999 Posted May 16, 2025 Report Posted May 16, 2025 13 hours ago, Gee Bee Aeroproducts said: Read the mil spec 193-2 306-2 milh5593 not for fuel and oil Safety is inexpensive. $25 and 15 minutes every few years seems to work okay.
cliffy Posted May 16, 2025 Report Posted May 16, 2025 I remember I went down the rabbit hole on this exact subject a few years ago I found by reading the actual MIL spec (attached) that 193-2 hose (to MIL spec MIL-H- 5593) actually had to pass some hydrocarbon testing using hot MIL-5606 fluid. Its contained in section 4.4.3.7 attached below file:///C:/Users/72773/Downloads/MIL-H-5593C%20(1).pdf It shows as a non-secure download but it down loads OK on my computer when forced Just for a point of reference- maybe why Mooney used it Its an old MIL spec I do like the idea of upsizing to #3 hose though
Skates97 Posted May 16, 2025 Report Posted May 16, 2025 19 hours ago, jamesm said: How do I deal with fitting coming off the carburetor for fuel pressure line? it's a -2 flare 90 degree looks to be a aluminum ( blue) fitting. The current installation doesn't go through the firewall. it has a ~ 25" long -2 hose going into an EI CGR30C/P pressure transducer which of course has a male fitting to a -2 hose flare fitting. mounted on one of Engine mount tubes. Can the carburetor fitting be aluminum? same with the EI transducer should be steel or aluminum or ??? Thanks for all the input. James '67C Be careful with that fitting on the carburetor, it has a reducer inside it and is expensive. When I had my engine replaced a year ago it was broken. I replaced that hose I think during annual in 2024, I can check my logbooks to see what was used this weekend.
jamesm Posted May 16, 2025 Author Report Posted May 16, 2025 This is what I found so far I could be a stretch but according to Mooney's Parts catalog that I have (see attached for photos as well) calls for AN6270-2-35 (#30 Part Cat). I am assuming ... -35 is length in inches and -2 is diameter of the hose. Application: Air or vacuum instrument systems, automatic pilots, and lines to pressure gauges used with these systems as specified in MS33620. Hose assemblies conform to AN6270. Hose conforms to MIL-DTL-5593. Fittings conform to MIL-DTL-38726 and MS27404. Supersedes AN773 For 306 am I missing something? I know the Eaton 306 vacuum and pressure lines but since Mooney calls it out in there Parts catalog does make valid to use 306 Hose? Thanks again for all the input and sorry for beating a dead horse over and over. I needed a reality check. James '67C carb_pressure_line.pdf
Gee Bee Aeroproducts Posted May 16, 2025 Report Posted May 16, 2025 Read the mil spec of the hose mil H 5593 Rubber Copper was used in most -2 fuel psi applications. The problem is it ages out From 1972 on up Beechcraft uses -3 on oil and manifold pressure -4 on fuel psi. I have a Cnc bender to mfg 304 tubing There must be a flex hose on both side of a fuel transducer. what was done in the past is not how it is done today. Iam asked to design these brackets and tubes by various shops for installations. 1
Skates97 Posted May 17, 2025 Report Posted May 17, 2025 Checked the log entry, Stratoflex 193-2 was used, cut to length and ends installed. Spruce says it is not rated for fuel, McFarlane says "designed to withstand most aircraft fuel, oil, coolants, solvents," https://www.mcfarlaneaviation.com/products/193-2/?srsltid=AfmBOoro-aCvjgIVazwt5eDcDAtYm7lg2s_WWXCVvHJ4fh9kwkkTfnHf https://www.desserhoses.com/dtr_hose_types_sizes.html#:~:text=Desser Hoses - Hose Types and,optioned with orange type firesleeve. There's this old post from Clarence saying the IPC shows 193-2. The IPC calls for AN6270-2 which according to Dresser is is MIL-H-5593 and is also 193. Sure miss having Clarence around. 2
Gee Bee Aeroproducts Posted May 17, 2025 Report Posted May 17, 2025 I only use rubber with clear shrink on early model master cylinder hoses as there is a clamp to attach the hose socket to airframe. 90% of the hoses we ship are tso Teflon in custom colors or shrink. I stock all beech landing gear hoses / new master cylinders / hardlines and we always send new adapters . PT6 hoses are 4775.00 to 9775.00 each / TSO Titeflex Since 1993 I sell quality, not price Other hose shops are limited on there capability based on there tso . Aeroquip Stratoflex They cannot mfg PT6 hoses as there not tso spec from Pratt Whitney. When all else fails, read the milspec and tso .
