PT20J Posted Tuesday at 06:02 PM Report Posted Tuesday at 06:02 PM I agree with @EricJ. The IPC is for identifying and ordering parts; it’s not an assembly drawing. 1 Quote
N201MKTurbo Posted Tuesday at 06:41 PM Report Posted Tuesday at 06:41 PM 1 hour ago, EricJ said: It's possible that the orientation of that link makes no difference. It would only matter if the OD of the bearings is different. I’ll be out at the plane later today. I’ll check it out. Quote
N201MKTurbo Posted Tuesday at 06:43 PM Report Posted Tuesday at 06:43 PM 40 minutes ago, PT20J said: I agree with @EricJ. The IPC is for identifying and ordering parts; it’s not an assembly drawing. I completely agree, but they are best assembly drawings we have. Does the maintenance manual have any guidance about this? Quote
PT20J Posted Tuesday at 06:59 PM Report Posted Tuesday at 06:59 PM 14 minutes ago, N201MKTurbo said: I completely agree, but they are best assembly drawings we have. Does the maintenance manual have any guidance about this? I didn’t see anything in the C-F manual. Here’s the drawing from the J manual with the newer type steering horn. 1 Quote
takair Posted Tuesday at 08:34 PM Report Posted Tuesday at 08:34 PM As I recall, you have to swing the gear with the nose gear doors open or the firewall panel removed to see the proximity of that bearing to the gear when turning. I think the flat gives just that extra amount of clearance to feel good when you see it. 1 Quote
N201MKTurbo Posted Wednesday at 03:36 AM Report Posted Wednesday at 03:36 AM I checked mine today. It is just like the 201 drawing above. I measured the OD of both ends and they are both 3/4”. There are no flats machined in either end. But it’s a J not a C. 1 Quote
cliffy Posted Wednesday at 06:05 AM Author Report Posted Wednesday at 06:05 AM 12 hours ago, EricJ said: It's possible that the orientation of that link makes no difference. I agree but I will check anyway 1 Quote
cliffy Posted Wednesday at 04:29 PM Author Report Posted Wednesday at 04:29 PM 19 hours ago, takair said: As I recall, you have to swing the gear with the nose gear doors open or the firewall panel removed to see the proximity of that bearing to the gear when turning. I think the flat gives just that extra amount of clearance to feel good when you see it. Correct In fact lots easier with the gear doors removed along with the tire and wheel The manual only talks to using the eccentrics for how high in the wheel well the tire goes and not to looking at this interference fit on the link rod at the same time. It was probably tribal knowledge 40 years ago at the factory. 2 Quote
cliffy Posted Wednesday at 08:16 PM Author Report Posted Wednesday at 08:16 PM The rod ends are listed in Heim's catalog in the "Aircraft Quality" section Aircraft quality means they are magnafluxed for cracks before delivery. Quote
47U Posted Friday at 07:12 AM Report Posted Friday at 07:12 AM On 4/23/2025 at 9:29 AM, cliffy said: The manual only talks to using the eccentrics for how high in the wheel well the tire goes and not to looking at this interference fit on the link rod at the same time. The fact that the mx manual doesn’t fully address the ramifications of the eccentric bushings is (I think) a pretty big deficiency. I only learned of them when I was trying to figure out why one of my nose gear extension tubes was so tight I couldn’t rotate it, and the other one was sloppy-loose. The eccentrics were not set to the same position. And, there is some evidence that at some point my nose tire had retracted high enough to leave skid marks on the top skin of the wheel well. To leave out the possibility of rudder interference and to also not explain the reason for the shaved Heim bearing and the steering link orientation… I’m fortunate for the smart people on this forum. Oh, and I fixed the orientation of my steering link. Interference must be a concern based on how much material is shaved off the Heim bearing. It’s almost down to the bearing insert. Quote
MB65E Posted Friday at 12:40 PM Report Posted Friday at 12:40 PM Is that to clear the grease fitting? We think? -Matt Quote
47U Posted Friday at 02:21 PM Report Posted Friday at 02:21 PM 1 hour ago, MB65E said: Is that to clear the grease fitting? We think? -Matt No, it’s well after. There’s no depth perception in this picture… the steering link arm is actually just aft of the zerk when the nose wheel is straight. Quote
Ragsf15e Posted Friday at 02:22 PM Report Posted Friday at 02:22 PM 7 hours ago, 47U said: The fact that the mx manual doesn’t fully address the ramifications of the eccentric bushings is (I think) a pretty big deficiency. I only learned of them when I was trying to figure out why one of my nose gear extension tubes was so tight I couldn’t rotate it, and the other one was sloppy-loose. The eccentrics were not set to the same position. And, there is some evidence that at some point my nose tire had retracted high enough to leave skid marks on the top skin of the wheel well. To leave out the possibility of rudder interference and to also not explain the reason for the shaved Heim bearing and the steering link orientation… I’m fortunate for the smart people on this forum. Oh, and I fixed the orientation of my steering link. Interference must be a concern based on how much material is shaved off the Heim bearing. It’s almost down to the bearing insert. Still interesting how yours has no threads showing. I have a brand new (from Mooney) female end of that heim joint, im going to see if it’s ground down like that, but I don’t think so. Weird. Quote
47U Posted Friday at 02:29 PM Report Posted Friday at 02:29 PM 4 minutes ago, Ragsf15e said: Still interesting how yours has no threads showing. Threads are hidden by the female end of the bearing. Reposting the picture below where I installed the link backwards… there’s some room for adjustment. Quote
cliffy Posted Friday at 03:25 PM Author Report Posted Friday at 03:25 PM I have seen one other Mooney that has the nose wheel skid marks on the top of the wheel well. A lot of info was taken for granted in the early models and their maintenance manuals. Take for instance the description of how to set the elevator bungees from the early short bodies to the J manual explanation. Lots more description in the J manual. Quote
cliffy Posted Friday at 03:35 PM Author Report Posted Friday at 03:35 PM 8 hours ago, 47U said: The fact that the mx manual doesn’t fully address the ramifications of the eccentric bushings is (I think) a pretty big deficiency. I only learned of them when I was trying to figure out why one of my nose gear extension tubes was so tight I couldn’t rotate it, and the other one was sloppy-loose. The eccentrics were not set to the same position. And, there is some evidence that at some point my nose tire had retracted high enough to leave skid marks on the top skin of the wheel well. To leave out the possibility of rudder interference and to also not explain the reason for the shaved Heim bearing and the steering link orientation… I’m fortunate for the smart people on this forum. Oh, and I fixed the orientation of my steering link. Interference must be a concern based on how much material is shaved off the Heim bearing. It’s almost down to the bearing insert. I've seen this before but wondering as to why one of the Heim joints had a castle nut and cotter pin (rotating joint) and the other doesn't (only a shake proof nut). Just wondering Same kind of connection (Yes I can be OCD at times) :-) But still that is one of the leanest nose gears around. I found one down in Australia that was MUCH better though. Couldn't believe how well that airplane was maintained It looked almost new everywhere.. 1 Quote
Ragsf15e Posted Friday at 03:46 PM Report Posted Friday at 03:46 PM 1 hour ago, 47U said: Threads are hidden by the female end of the bearing. Reposting the picture below where I installed the link backwards… there’s some room for adjustment. Ahh, that makes sense! Quote
47U Posted Friday at 03:57 PM Report Posted Friday at 03:57 PM 13 minutes ago, cliffy said: I've seen this before but wondering as to why one of the Heim joints had a castle nut and cotter pin (rotating joint) and the other doesn't (only a shake proof nut). Just wondering Same kind of connection It made no sense to me, either. I referenced three Mooney vintage IPCs (‘62-‘64, ‘65-‘67, & ‘’68-‘76) to try to get the hardware correct. They all show the drilled bolt with cotter pin in front and undrilled bolt in the back. Sometimes though, you just go back to standard installation practices for hardware in 43-13… or more relevant to my experience, T.O. 1-1A-8. Quote
cliffy Posted Friday at 03:59 PM Author Report Posted Friday at 03:59 PM 1 minute ago, 47U said: It made no sense to me, either. I referenced three Mooney vintage IPCs (‘62-‘64, ‘65-‘67, & ‘’68-‘76) to try to get the hardware correct. They all show the drilled bolt with cotter pin in front and undrilled bolt in the back. Sometimes though, you just go back to standard installation practices for hardware in 43-13… or more relevant to my experience, T.O. 1-1A-8. YUP :-) :-) 1 Quote
Ragsf15e Posted Friday at 05:05 PM Report Posted Friday at 05:05 PM Here’s pictures of a brand new one from Mooney… Quote
Fly Boomer Posted Saturday at 10:42 PM Report Posted Saturday at 10:42 PM On 4/23/2025 at 3:16 PM, cliffy said: Aircraft quality means they are magnafluxed for cracks before delivery. I thought “aircraft quality” meant ten times as expensive. Quote
cliffy Posted 7 hours ago Author Report Posted 7 hours ago On 4/26/2025 at 4:42 PM, Fly Boomer said: I thought “aircraft quality” meant ten times as expensive. Go there nd check the prices! Quote
