Lumberg Posted February 25 Report Posted February 25 " No agenda, no argument, no bias, No Comment. " - accredited to EuroNews Quote
LANCECASPER Posted February 25 Report Posted February 25 It looks like it's only approved for Cessnas (and Reims), but it looks like a direct replacement. https://www.aircraftspruce.com/catalog/elpages/igswitches.php They also have another kit with the ignition switch and locks that use the same key for baggage and door. https://www.aircraftspruce.com/catalog/elpages/igswitches2.php?clickkey=13673 Quote
Fly Boomer Posted February 25 Report Posted February 25 3 minutes ago, LANCECASPER said: It looks like it's only approved for Cessnas (and Reims), but it looks like a direct replacement. https://www.aircraftspruce.com/catalog/elpages/igswitches.php Without Push To Start, if you have SOS, it might require a wiring change. Quote
Andy95W Posted February 25 Report Posted February 25 I installed one in my M20C. Wired per the installation diagram for the Shower-of-Sparks. It works great. The justification for an M20B or C is more straightforward, because originally those airplanes were equipped with a switch of similar architecture and function. I simply noted that I reverted the aircraft back to a previous configuration applicable to earlier serial numbers. For the airworthiness of the specific part, I referred to the PMA for other aircraft types. I wrote it all up on a 337, noting the changes to the aircraft Owner’s Manual, and my FSDO agreed that as written it was indeed a minor alteration. You will lose the ability to hand-prop your airplane, and you will need an IA who is agreeable to this as a minor alteration. 1 Quote
