Htmlkid Posted February 24 Report Posted February 24 https://www.trade-a-plane.com/search?category_level1=Single+Engine+Piston&make=MOONEY&model=M20J+205&listing_id=2427252&s-type=aircraft 1 Quote
Slick Nick Posted February 24 Report Posted February 24 How do you like the 390 engine? Is the extra 10hp worth the cost of the STC? Quote
Htmlkid Posted February 25 Author Report Posted February 25 2 hours ago, Slick Nick said: How do you like the 390 engine? Is the extra 10hp worth the cost of the STC? The previous owner did it in lue of an overhaul. I can only compare it to my previous F which had an IO 360 and it does give you a better climb. As for cruise, I dont push the engine but I comfortably get 160kts burning 9.5gph Quote
TangoTango Posted February 26 Report Posted February 26 On 2/24/2025 at 8:29 PM, varlajo said: If only 390 was compatible with UL94... I don't think the IO-360A3B6D this would've come from the factory with is compatible, either Quote
