GeeBee Posted February 3 Report Posted February 3 1 hour ago, Pinecone said: Did not know that. It also goes the other way. Some years back I was being ramp checked in Amsterdam and was asked to produce my "EASA Foreign Air Carrier Certificate". The inspector says a copy must be carried in each aircraft. A phone call to the Ops Center and a discussion with the Regulatory Desk" revealed that my company had an operations specification with EASA that stated the certificates were retained at corporate headquarters. All ended well. Quote
DXB Posted Wednesday at 12:13 AM Author Report Posted Wednesday at 12:13 AM Apparently the CVR was at the base of the main impact crater - blows my mind that this thing is predicted to be readable 1 Quote
EricJ Posted Wednesday at 02:31 AM Report Posted Wednesday at 02:31 AM 2 hours ago, DXB said: Apparently the CVR was at the base of the main impact crater - blows my mind that this thing is predicted to be readable Wow. That'll be impressive if they do get the data out. That's some good system and implementation engineering right there if it works. Quote
Schllc Posted Wednesday at 02:43 AM Report Posted Wednesday at 02:43 AM I’m impressed by the energy of that impact. Those engines had to be making full thrust all the way to impact. Quote
Hank Posted Wednesday at 02:55 AM Report Posted Wednesday at 02:55 AM 9 minutes ago, Schllc said: I’m impressed by the energy of that impact. Those engines had to be making full thrust all the way to impact. In the video, it looked at lot like a missle coming down. Anyone know where in the Lear the CVR is installed? Cockpit or rear avionics bay? Regardless, 8' under a road or parking lot is pretty deep, meaning a large amount of kinetic energy. Quote
Pinecone Posted Wednesday at 03:18 AM Report Posted Wednesday at 03:18 AM 46 minutes ago, EricJ said: Wow. That'll be impressive if they do get the data out. That's some good system and implementation engineering right there if it works. It doesn't have to work. The recording media just needs to be recoverable. Quote
MikeOH Posted Wednesday at 04:44 AM Report Posted Wednesday at 04:44 AM 1 hour ago, Pinecone said: It doesn't have to work. The recording media just needs to be recoverable. Pretty sure @EricJ knows that. That’s as close to a ‘black’ box as I’ve seen; the ability of the media to withstand not only the impact but the temperature is definitely impressive engineering! Quote
N201MKTurbo Posted Wednesday at 10:39 AM Report Posted Wednesday at 10:39 AM 5 hours ago, MikeOH said: Pretty sure @EricJ knows that. That’s as close to a ‘black’ box as I’ve seen; the ability of the media to withstand not only the impact but the temperature is definitely impressive engineering! I’m sure they abuse it worse than that in development. Quote
GeeBee Posted Wednesday at 01:36 PM Report Posted Wednesday at 01:36 PM Required to withstand 3400g and 1100 degrees C and maintain data integrity. Quote
redbaron1982 Posted Wednesday at 01:51 PM Report Posted Wednesday at 01:51 PM 13 hours ago, DXB said: Apparently the CVR was at the base of the main impact crater - blows my mind that this thing is predicted to be readable Related, but unrelated, do I need an X account now to keep updated on NTSB investigations? I know I can access X without an account, but it seems that the posts are not sorted chronologically, so it is kind of useless. Quote
MikeOH Posted Wednesday at 03:44 PM Report Posted Wednesday at 03:44 PM 2 hours ago, GeeBee said: Required to withstand 3400g and 1100 degrees C and maintain data integrity. How long at 1100C? Do you have a cite for the specs? Quote
GeeBee Posted Wednesday at 03:55 PM Report Posted Wednesday at 03:55 PM 10 minutes ago, MikeOH said: How long at 1100C? Do you have a cite for the specs? 60 minutes https://skybrary.aero/sites/default/files/bookshelf/3679.pdf 1 Quote
A64Pilot Posted Wednesday at 05:56 PM Report Posted Wednesday at 05:56 PM On 2/2/2025 at 8:27 PM, MikeOH said: Any reasonably statistical basis for that comment, or just your opinion? Easy, search aircraft values with an XA registration vs ones with an N registration. IF it was a maintenance induced crash, mechanic competence comes into question more than pilot. Quote
A64Pilot Posted Wednesday at 05:59 PM Report Posted Wednesday at 05:59 PM (edited) On 2/2/2025 at 8:44 PM, MooneyMitch said: Someone mentioned a possible major weigh shift, due to lack of equipment securing, causing a situation rendering the flight control useless and an eventual stall. I recall this with a 747 out of Afghanistan several years ago. Huge cargo shift that caused that crash [on video]. Regarding the fire issue.........again someone mentioned that what appears to be the jet on fire, is possibly the aircraft forward lights reflecting [at times intermittent] off of the broken clouds during the rapid decent I believe that there was a CG shift, but what was more of the cause of the crash was the MRAP vehicle took out the elevator jack screw taking I think the stabalitor into full or near full up. https://en.wikipedia.org/wiki/National_Airlines_Flight_102 Edited Wednesday at 06:04 PM by A64Pilot Quote
A64Pilot Posted Wednesday at 06:02 PM Report Posted Wednesday at 06:02 PM (edited) CVR question I believe is more of how old was it than the forces at impact, old ones often don’t work and the old tape and or wire recorders aren’t as robust as the newer solid state ones. ‘If there is still paint on it, it didn’t get that hot. Lear 55 is an old aircraft? Edited Wednesday at 06:05 PM by A64Pilot Quote
