Mooney in Oz Posted February 18 Report Posted February 18 5 hours ago, Ragsf15e said: Guess I’m a little late to post pictures of the new bird, but here she is! She needs some interior work on the yellowed plastics and the paint is original, but everything else is great - 1700hrs tt, 200smoh 3 years ago, maintained at Cole MSC, etc. Looking forward to lots of family trips! (And if anyone wants to help/teach me the plastic restoration process, much appreciated!) Great looking bird, including the panel. Congrats! 1
EricJ Posted February 18 Report Posted February 18 7 hours ago, Ragsf15e said: (And if anyone wants to help/teach me the plastic restoration process, much appreciated! Most of it is ABS plastic, which is the easiest thing in the world to work with for doing repairs. There are tons of YT vids, because lots of people do it, and there are several techniques and most of them are pretty easy to do (e.g., weld it with a soldering iron, make a slurry glue/filler with acetone and ground up ABS, etc., etc). Texture it and paint it to the desired color, etc., etc. It just takes a little practice on some scrap stuff, which is easy to find, and you'll likely be good to go and making it look like new. And repairing interior "decorative" pieces are all completely within Preventive Maintenance, so there's no barrier to you doing it all yourself. Oh, and nice airplane! That looks like quite the score. 1
Pinecone Posted February 19 Report Posted February 19 On 2/16/2025 at 2:56 PM, EricJ said: It's normally been in the water for long periods of time before it flew down here. The thing coming off of the tail of the wing tip float is part of a boom circle that was around the entire airplane. It's also attached to the nose. I don't know what the boom was for other than potentially to keep curious kayakers or boarders out (which I think is also why the pontoon boats were there), or to help keep leaking oil or fuel a little bit contained around the airplane. Oil. Most states have standards about no sheen on the water. And radials LEAK. And this airplane has Wright engines. The old timers say never attempt to fly a Wright engine that is not leaking oil. It means it is empty. 1 1
C.J. Posted February 19 Report Posted February 19 On 2/18/2025 at 12:42 AM, Ragsf15e said: (And if anyone wants to help/teach me the plastic restoration process, much appreciated!) I'm in the middle of a plastic repair & restore process right now. I recommend S.E.M. products, specifically their soap, adhesion promoter & paint. My results have been great. Just follow their directions. By all means get a respirator AND goggles because the adhesion promoter & paint fumes are horrible. You'll need nitrile (or neoprene) gloves and unless you want your finger to cramp up get a "Can Gun" aerosol spray trigger from Aircraft Spruce. Paint on a calm day ideally between 70* to 85*F. It's best to apply several very light coats (up to 7 or 8 in my case). It dries very fast but wait the directed amount of time between coats. If you've never spray painted before watch a YouTube video for proper technique. It's not difficult but I practiced on an old cardboard box just 3 times until I had it perfected. Leave your finished work to cure for a day or two before handling. Most if not all odors will have dissipated by then unless the ambient temperatures have been cool. Fun Facts - S.E.M. paint is expensive but totally worth it. IIRC McFarlane sells a limited number of colors and had it for a good price. Unfortunately, not the specific color I wanted. O'Relly Auto Parts was pricey and had supply chain issues. Amazon saved the day and was by far the least expensive but be aware they don't have returns on paint due to it being HazMat. Calculate your square footage necessary and order conservatively knowing you can always order more if needed. For cracks in the plastic, I initially tried "Satellite City" instant glue, specifically their "Hot Stuff" and "Super 'T'" product. It has the viscosity of water which I found difficult to control and the results were not what I'd hoped for. I ended up using 7 Quarical Easy ABS Repair Tips for Easy Plastic Solutions which is an all-in-one pre-mixed ABS solution which proved to be outstanding. My headliner had some very bad cracks, splits & holes The ABS resin resembles tar and is applied from the back so no will ever see it. Time will tell if it holds up but I'm very optimistic. If you need more specifics just send me a DM. It'd be easier to explain it on the phone. BTW great looking Mooney. Wow!!! 2 2
Pinecone Posted February 23 Report Posted February 23 FYI, I fell in love with Mercury Adhesives for instant glues. They have from water thin to fairly thick. And the bottles are designed to not get stuck caps. I got my last set from Amazon. And there is a medium viscosity flexible version https://www.amazon.com/Mercury-Adhesives-M300FM-FLEX-medium/dp/B01K5YHJUE/ref=pd_lpo_d_sccl_3/139-9850247-7007301?pd_rd_w=Ywdju&content-id=amzn1.sym.4c8c52db-06f8-4e42-8e56-912796f2ea6c&pf_rd_p=4c8c52db-06f8-4e42-8e56-912796f2ea6c&pf_rd_r=VFDC6A37A4VCDYBVYPWJ&pd_rd_wg=m3pRj&pd_rd_r=2b7475b4-456a-42ad-9bcb-b7c2e57d9d65&pd_rd_i=B01K5YHJUE&psc=1
EricJ Posted March 2 Report Posted March 2 Look who we parked next to at Sedona yesterday! Didn't see Matt, just his airplane. It was still there when we left mid-afternoon. There was also a very, very nice F-model just across from us. 1
Hank Posted March 2 Report Posted March 2 17 minutes ago, EricJ said: Look who we parked next to at Sedona yesterday! Didn't see Matt, just his airplane. It was still there when we left mid-afternoon. There was also a very, very nice F-model just across from us. The tail on that plane in the background ("Matt"''s plane?) has its tail on backwards . . . 1
toto Posted March 2 Report Posted March 2 4 minutes ago, Hank said: The tail on that plane in the background ("Matt"''s plane?) has its tail on backwards . . . I think he’s talking about YouTuber Matt Guthmiller 1
EricJ Posted March 2 Report Posted March 2 1 hour ago, toto said: I think he’s talking about YouTuber Matt Guthmiller Yes, I probably shouldn't assume people know that airplane.
toto Posted March 2 Report Posted March 2 2 hours ago, EricJ said: Yes, I probably shouldn't assume people know that airplane. He seems to be flying an L-39 or a TBM so often these days, I almost forget that he has a Bonanza. 1
EricJ Posted March 2 Report Posted March 2 59 minutes ago, toto said: He seems to be flying an L-39 or a TBM so often these days, I almost forget that he has a Bonanza. I kinda stopped watching his channel when he started the L-39 stuff. He lives at the airpark in Alpine, WY, which I visit occassionally because I know other people who live there, so I get some of the neighbor updates about him that way.
toto Posted March 2 Report Posted March 2 22 minutes ago, EricJ said: I kinda stopped watching his channel when he started the L-39 stuff. He lives at the airpark in Alpine, WY, which I visit occassionally because I know other people who live there, so I get some of the neighbor updates about him that way. Yeah, same. His story is interesting, and his Bonanza content was reliably good. But I never really understood what they were doing with the L-39 business, and the weird Amazon TBM that was supposed to be used for another around-the-world flight has been a head-scratcher. Alpine is a nice airpark, but there’s plenty of other aviation content from there. 1
Ibra Posted March 6 Report Posted March 6 (edited) Picked aircraft from it's annual, and flew VFR the afternoon in Belgium and night in France, finally I bited the bullet and installed new LED to replace old bulbs, following advice from Mooniacs here ! That's a nice call sign (goes well with "OH-FBI") Sunset over Amiens (LFAY) Edited March 6 by Ibra 3
EricJ Posted March 9 Report Posted March 9 Had a big weather system come through and dump a bunch of snow, so we went up to take a look. This is the Sedona area on the way back. You can see the airport on the mesa toward the upper right of the pic. 5
Echo Posted March 9 Report Posted March 9 I recently returned to Iowa from Arkansas and had a significant headwind out of the north. I was in cruise at 5500’ burning 10.3gph. 2500rpm and 2350mp. On landing I went no flaps. Wind was19 gusting to 36 @290. Landing was uneventful on 31. My indicated airspeed on final was 120-100mph or sink was significant. Here was groundspeed. 1 1
Ragsf15e Posted March 9 Report Posted March 9 Two weeks ago spring arrived and our skiing went to crap. Decided to go visit my parents down in Nevada. First trip in the new airplane and must have been doing something right because we had a tailwind both down (Fri) and back (Sun). Only 20kts on the way down though, the way back was even better!! Apparently we even did an aileron roll! 2 7
Hank Posted March 13 Report Posted March 13 Just finished annual and flew her home. It's was just under two weeks, and I didn't quite forget how to fly. The weather was gorgeous, mid 70s, clear skies until I took off; that haze was surprising after the clear winter days, and surprisingly low as i flew 20-odd miles home at 3000 msl, right in the brown yuck. And who doesn't like a video? My wife did this on my first takeoff, around the pattern and down, to make sure everything works right. Check out those fast gear moving up! 4
wombat Posted March 27 Report Posted March 27 (edited) Just got my annual finished. Flew down to Santa Maria to Artcraft Paint to have them take a look at the plane. Chances are pretty good I'll be taking it to them this fall for a full repaint and interior. Some pictures: Some buildups over the Cascades on the return trip today (26 March). They'd been predicting 1/2" hail, but unless something drastic changes I don't see those clouds producing anything that wild. I had a tailwind of up to 60 knots on the return trip at 16,000'. Lake Tahoe on the way North today, from 16,000' Sunset over the low clouds over the ocean on Tuesday evening. (24 March) (OVC 800 at SMX so it was an instrument approach and landing with a tailwind because the other runways have too high of minimums and the circling approach mins are 800'... And I'm not about to do my first circling approach in 7 years in the dark right at minimums) Crater Lake from Tuesday afternoon (25 March): Edited March 27 by wombat Formatting 5
0TreeLemur Posted March 28 Report Posted March 28 N201Y flies again! When we bought our J in 2022 it came with tail number N202Y. Right next to the sticker that says "Mooney 201", it just struck me as not quite right. Last fall on a whim I checked the FAA N-number web site to see if maybe N201Y was available and it was! After a few weekends of sanding, taping, painting, it's done. Yesterday I reprogrammed the transponder and flew to HAB for some $4.30/gal go juice. N201Y just rolls off the tongue, and I never once said N202Y. Here she sits on the ground at HAB. Showed up on flight aware as N201Y. This tail number previously was worn by a J model that was seemingly "retired". The total cost was $10 to the FAA, $110 for some two-component paint, $50 for miscellaneous sanding/painting supplies plus about 40 hours of my labor. Not quite done- I need to sand some edges and paint the shadow on the new "1"s. 6
Mooney in Oz Posted March 29 Report Posted March 29 On 3/27/2025 at 12:04 PM, wombat said: I had a tailwind of up to 60 knots on the return trip at 16,000'. What was your ground speed?
wombat Posted March 29 Report Posted March 29 The fastest I saw was 259KT ground speed but 250 was closer to average for the highest tailwind portion. https://www.flightaware.com/live/flight/N5773S/history/20250326/1755Z/KSMX/S35 ATC called at one point to ask what my tailwind was. I should have told them "It's a 30 knot headwind, but I did just install a PowerFlow exhaust!" But I didn't think that quickly. 2 1
Ibra Posted April 7 Report Posted April 7 (edited) Flew from France (Rouen LFOP) to Netherlands (Leylstad EHLE) to visit Luchtvaartmuseum, a nice collection of Dutch aviation heritage ! Nice weather all the way, we overflew tulipes farms at Keukenhof, it's not yet the season, so I had to go down to 500ft from time to time DC2 that flew Netherlands to Australia kids friendly playground (also for adults who never had the chance to grow or get spoiled) Edited April 7 by Ibra 7
dkkim73 Posted April 7 Report Posted April 7 2 hours ago, Ibra said: DC2 that flew Netherlands to Australia kids friendly playground (also for adults who never had the chance to grow or get spoiled) How true! 1
exM20K Posted April 10 Report Posted April 10 This was tough to see from the air. The flooding in central Kentucky is widespread, and while what I flew over appeared not to get beyond the river floodplain, there were definitely homes inundated or cut off. I read news reports of much of the state capitol being flooded. -dan 1 1
exM20K Posted April 10 Report Posted April 10 The remnants of a controlled burn north of Apalachicola. After I landed, I did a few laps to get night current, and the views were way more dramatic, but I had no spare hands to take pictures, regrettably. -dan 3 1
