Martin S. Posted December 1, 2024 Report Posted December 1, 2024 Hello gents, Question on the Weldon boost pumps, trying to find out which one I would need for my M20J (24-0520). Aircraftspruce lists the 18020-A and also the A8163-A for my serial number. If it matters, I had a dukes 1499-00-19 installed, engine is an A3b6d. Martin Quote
Fly Boomer Posted December 1, 2024 Report Posted December 1, 2024 1 hour ago, Martin S. said: Hello gents, Question on the Weldon boost pumps, trying to find out which one I would need for my M20J (24-0520). Aircraftspruce lists the 18020-A and also the A8163-A for my serial number. If it matters, I had a dukes 1499-00-19 installed, engine is an A3b6d. Martin The only IPC for an M20J I have says Dukes 1499-00-19/19A is replaced with Weldon A8163-A, but you need retrofit kit #940018 to do the swap. I'm sure someone else more knowledgeable will be along shortly. Usually, people have these rebuilt. Quote
Martin S. Posted December 1, 2024 Author Report Posted December 1, 2024 9 minutes ago, Fly Boomer said: The only IPC for an M20J I have says Dukes 1499-00-19/19A is replaced with Weldon A8163-A, but you need retrofit kit #940018 to do the swap. I'm sure someone else more knowledgeable will be along shortly. Usually, people have these rebuilt. Thanks - I didn’t know it requires modification. Did a quick search, seems like the mod takes quite some labor. This will definitely make me reconsider whether I shouldn’t simply overhaul my dukes. Does any of the European pilots know whether there’s a company that does dukes pump overhaul on this side of the Atlantic? Otherwise I guess I’ll contact Aeromotors LLC. Quote
Fly Boomer Posted December 1, 2024 Report Posted December 1, 2024 1 hour ago, Martin S. said: Otherwise I guess I’ll contact Aeromotors LLC. Aeromotors is the name that comes up most often. I suspect the shipping is brutal. Quote
Martin S. Posted December 6, 2024 Author Report Posted December 6, 2024 Does anybody now which fittings to use for the Dukes pump drain nipple? The IPC mentions B-1-ON-2. Where can these be found and/or is there another name for these? Quote
N201MKTurbo Posted December 6, 2024 Report Posted December 6, 2024 See the last page. The fitting is a Dukes part 2140-93 https://mooney.com/wp-content/uploads/2020/12/SBM20-222B.pdf Quote
Martin S. Posted December 6, 2024 Author Report Posted December 6, 2024 36 minutes ago, N201MKTurbo said: See the last page. The fitting is a Dukes part 2140-93 https://mooney.com/wp-content/uploads/2020/12/SBM20-222B.pdf Thanks! Quote
