AJ88V Posted October 13, 2024 Report Posted October 13, 2024 Putting together an order for ACSpruce and welcome your suggestions. I already bought packs for the external inspection covers, but I'm looking for some the small screws, washers, Tinnermans, etc. for the interior panels. Suggestions? Is the a pre-packed kit for another plane that has a lot of the pieces I need? Quote
PT20J Posted October 13, 2024 Report Posted October 13, 2024 Be careful if you ordered one of the pre-packaged screw kits. I found that some of the screws were too long. In most places it doesn't matter, but there are a couple of inspection panels where screws longer than called out in the IPC can damage control push-pull tubes. 2 Quote
AJ88V Posted October 13, 2024 Author Report Posted October 13, 2024 That's a good warning. Most of my inspection panel screws were replaced with stainless years ago when I had the plane painted, but I did replace specific machine screws where the heads have gotten chewed up over the years. The stainless is a lot softer than the regular steel. Quote
EricJ Posted October 13, 2024 Report Posted October 13, 2024 There's not a pack that I'm aware of for the interior hardware that holds things like the plastic panels, etc., together, but you can get all that at the aviation aisle of Ace Hardware or similar places. At least, that's where I get mine. Quote
Marc_B Posted October 13, 2024 Report Posted October 13, 2024 I believe they are mostly #6 and #4 screws and some have finishing washers. But they're cheap enough that you could order 50 of each length that you think you might need. Some of the smaller ones around trim are the shorter ones. Some of the overhead are longer ones. If you're just replacing ones with marred heads, it should hopefully be easy to see which ones you need... But caveat...these are the screws that I used for my M20K...I'm not sure if they are the same for the M20C, but figured it's at least a good place to start. What does your IPC show for PN's? Part# 04-03898 39104C FINISHING WASHER Part# 04-03899 WASHER NAS391B6P / 601-6 39106C Part# T4X6 4X3/8-A-TR-PH-SS SHT MET SCREW Part# 04-00166 4X3/8-B-TR-PH-SS TAPPING SCREW Part# O6X8 6X1/2-A-OV-PH-SS OVAL SS SCREW Part# O6X12 6X3/4-A-OV-PH-SS OVAL SS SCREW Part# O6X16 6X1-A-OV-PH-SS OVAL SS SCREW 1 Quote
PT20J Posted October 14, 2024 Report Posted October 14, 2024 My IA says he has had stainless screws gall and jam in nutplates and now he puts anti seize on them. I’ve never had an issue. Has anyone else had issues with stainless screws galling? Quote
AJ88V Posted October 14, 2024 Author Report Posted October 14, 2024 49 minutes ago, PT20J said: My IA says he has had stainless screws gall and jam in nutplates and now he puts anti seize on them. I’ve never had an issue. Has anyone else had issues with stainless screws galling? YES! I always use anti-seize paste (the silver stuff). Note only needed on the machine thread screws. I've had a ton of them do that, or at least make them very hard to remove. T his is compounded by the fact that the stainless steel screws are softer and the Phillips heads strip - especially when using a drill! Interesting tidbit: Back in the WWII era, mechanics would use a drop of Milk of Magnesia on the threads as an anti-seize treatment. I can attest that it works very well on the stainless screws and I've used it things like exhaust headers on motorcycles over the years because it doesn't smoke. 1 Quote
AJ88V Posted October 14, 2024 Author Report Posted October 14, 2024 15 hours ago, Marc_B said: I believe they are mostly #6 and #4 screws and some have finishing washers. But they're cheap enough that you could order 50 of each length that you think you might need. Some of the smaller ones around trim are the shorter ones. Some of the overhead are longer ones. If you're just replacing ones with marred heads, it should hopefully be easy to see which ones you need... But caveat...these are the screws that I used for my M20K...I'm not sure if they are the same for the M20C, but figured it's at least a good place to start. What does your IPC show for PN's? Part# 04-03898 39104C FINISHING WASHER Part# 04-03899 WASHER NAS391B6P / 601-6 39106C Part# T4X6 4X3/8-A-TR-PH-SS SHT MET SCREW Part# 04-00166 4X3/8-B-TR-PH-SS TAPPING SCREW Part# O6X8 6X1/2-A-OV-PH-SS OVAL SS SCREW Part# O6X12 6X3/4-A-OV-PH-SS OVAL SS SCREW Part# O6X16 6X1-A-OV-PH-SS OVAL SS SCREW Thanks for this list. It was the #4 and #6 screws I wanted. Also, thanks for the suggestion to check the Parts Catalog which I was able to find here in the Browse/Downloads section (awesome!!!) https://mooneyspace.com/files/ FWIW, my A&P shop is kind to let me swipe the occasional screw, but I want to replace some of the old hardware as I start working on the interior of the plane. These little ones are so cheap on Spruce that I'm making a little kit. Thanks! 1 Quote
Nick G Posted Friday at 06:12 PM Report Posted Friday at 06:12 PM I'm looking for the small headliner screws. They appear to be beige in color. I have a part number from Money but they don't have them ANy guidance on where to get color-matched screws? Quote
MikeOH Posted Friday at 06:52 PM Report Posted Friday at 06:52 PM 39 minutes ago, Nick G said: I'm looking for the small headliner screws. They appear to be beige in color. I have a part number from Money but they don't have them ANy guidance on where to get color-matched screws? TESTOR's model paint? 1 Quote
PT20J Posted Friday at 08:09 PM Report Posted Friday at 08:09 PM Just get some #4 sheet metal screws from the hardware store and paint them. 1 Quote
Slick Nick Posted Saturday at 10:36 PM Report Posted Saturday at 10:36 PM On 10/14/2024 at 10:23 AM, PT20J said: My IA says he has had stainless screws gall and jam in nutplates and now he puts anti seize on them. I’ve never had an issue. Has anyone else had issues with stainless screws galling? Yes. Especially the underwing access panels and ones on the tail. I use nickel based anti seize. Quote
N201MKTurbo Posted Saturday at 11:02 PM Report Posted Saturday at 11:02 PM 24 minutes ago, Slick Nick said: Yes. Especially the underwing access panels and ones on the tail. I use nickel based anti seize. I just put the screws in a Dixie cup and spray them with LPS before I put them in, they never stick. Quote
laytonl Posted yesterday at 01:41 AM Report Posted yesterday at 01:41 AM On 8/2/2025 at 7:02 PM, N201MKTurbo said: I just put the screws in a Dixie cup and spray them with LPS before I put them in, they never stick. Me too. I always spray the screws with LPS before reinstalling. Rarely have any problems. Lee 2 Quote
