Tyler G Posted May 16, 2024 Report Posted May 16, 2024 (edited) I'm reaching out to see if anyone knows a skilled Aircraft Maintenance Engineer (AME) who can help me with some crucial tasks on my 1996 Mooney Ovation (C-GJOG). Specifically, I need assistance with mounting the engine and propeller. There are also a few other items that need attention. The aircraft has been grounded for nearly a year. Unfortunately, my current AME hasn't been able to make any progress or provide a timeline, and I really need to get these tasks completed as soon as possible. If you know someone who could help or if you have any recommendations, please let me know. Your assistance would be greatly appreciated. The plane is currently sitting in MY hanger. Edited May 16, 2024 by Tyler G Quote
Fly Boomer Posted May 16, 2024 Report Posted May 16, 2024 2 minutes ago, Tyler G said: Specifically, I need assistance with mounting the engine and propeller If your current mechanic has it in his hangar, you have two problems: 1) retrieve the airplane and as many parts as you can find and, 2) get a new mechanic to come to the airplane. The first problem is not insignificant, but the second problem will likely be monumental. Quote
PeteMc Posted May 16, 2024 Report Posted May 16, 2024 Hopefully someone here will have a contact for you. But I'd also suggest posting something on Facebook in the Flights Above The Pacific Northwest - FATPNW group. And is it a C or N registered aircraft? That will probably also be a factor. Quote
Tyler G Posted May 16, 2024 Author Report Posted May 16, 2024 3 minutes ago, PeteMc said: Hopefully someone here will have a contact for you. But I'd also suggest posting something on Facebook in the Flights Above The Pacific Northwest - FATPNW group. And is it a C or N registered aircraft? That will probably also be a factor. Thank you. I will try that. Quote
glenn reynolds Posted June 23, 2024 Report Posted June 23, 2024 My recommendation would be airsea in Campbell river. I have had them work on my Mooney ovation and they have more resources than any other shop I have ever used. While they are not Mooney men per say, when you walk through the three hangers and look at the projects they are doing, which include hanging diesel engines on beavers and taking smashed turbine airplanes which arrive in a shipping container with fuselage twist, you will see that they have both the engineering and the fabrication skills. They also do salvage recovery work so their team is not adverse to travel. I can also say that their prices was very fair. Hope this helps. Quote
Fly Boomer Posted June 23, 2024 Report Posted June 23, 2024 7 hours ago, glenn reynolds said: airsea in Campbell river Could not find them on the web. The text file you attached contains the following. I could not make heads or tails of that either. {"groups":{"#cc3333":{"div":"#box1","label":"","paths":["BC","AK","OR","AZ","UT","ID","ON","PE","NS","NB","NH","VT","MA","CT","RI","NY","PA","NJ","VA","SC","GA","FL","TX"]},"#ff2000":{"div":"#box2","label":"","paths":["ND"]},"#80cdc1":{"div":"#box3","label":"","paths":["SD"]},"#b30000":{"div":"#box4","label":"","paths":["WY"]},"#2b8cbe":{"div":"#box5","label":"","paths":["MO"]},"#ffed6f":{"div":"#box6","label":"","paths":["MN","TN","IL","OK","NV"]},"#00c957":{"div":"#box7","label":"","paths":["WI","NM","OH","MS","KS"]},"#0868ac":{"div":"#box8","label":"","paths":["IN","MD","CO","LA","AL","NE"]},"#41ae76":{"div":"#box9","label":"","paths":["WA","YT"]},"#f7fcfd":{"div":"#box10","label":"","paths":["IA","WV"]},"#fc4e2a":{"div":"#box11","label":"","paths":["MI","KY","AR"]},"#1d91c0":{"div":"#box12","label":"","paths":["NC","ME"]},"#377eb8":{"div":"#box13","label":"","paths":["CA","MT"]}},"title":"","hidden":[],"background":"#ffffff","borders":"#000000"} Quote
PeteMc Posted June 23, 2024 Report Posted June 23, 2024 10 hours ago, Fly Boomer said: Could not find them on the web. Just a quick look in ForeFlight for CYBL I found Sealand Aviation Ltd (250-204-1086) that shows "Aircraft" maintenance as well as Seaplane maintenance. Quote
Fly Boomer Posted June 24, 2024 Report Posted June 24, 2024 3 hours ago, PeteMc said: Just a quick look in ForeFlight for CYBL I found Sealand Aviation Ltd (250-204-1086) that shows "Aircraft" maintenance as well as Seaplane maintenance. Got it. I was searching for "airsea in Campbell River". Stupid computer couldn't figure it out. I can't wait for AI. Thanks. Quote
glenn reynolds Posted June 24, 2024 Report Posted June 24, 2024 My apologies, my memory got it a little convoluted. there are two divisions: the flight training group and the repair and maintenance division. Here is the link to the repair division https://www.sealandaviation.com/?q=overhaul-aircraft-engines.php Quote
Tyler G Posted June 24, 2024 Author Report Posted June 24, 2024 52 minutes ago, glenn reynolds said: My apologies, my memory got it a little convoluted. there are two divisions: the flight training group and the repair and maintenance division. Here is the link to the repair division https://www.sealandaviation.com/?q=overhaul-aircraft-engines.php Thank you very much. They look pretty solid. Quote
