Garmin Aviation Database Manager Sync Update - Failing to perform single-card Sync
I have two updatable Garmin devices in my plane, a GTN and a G500.
Garmin used to be able to do a Sync update where it would update both devices from a single card using the Garmin Aviation Database Manager software.  It still claims it can do that, but it insists on putting the Airport Directory on a second card.  This DB is supposed to sync from the 750 to the G500.
Is anyone else having this problem?
Just in case, there was an update to the db manager on my machine today. May want to see if that has been done on your machine and then try again…
-Don
I did get the update today and these screenshots are from after the update.   :(
Good point though to make sure to have the latest software.
