Sheriff23 Posted March 23 Report Posted March 23 MooneySpace, I upgraded my panel to a G3X touch with EIS. This allowed me to remove the EDM-830. I always upload my engine data to Savvy, but I can’t figure out how. I am a ForeFlight pilot and I don’t use Garmin Pilot. I will appreciate any pointers! Thanks, Sheriff Sent from my iPhone using Tapatalk Quote
Fly Boomer Posted March 23 Report Posted March 23 5 minutes ago, Sheriff23 said: MooneySpace, I upgraded my panel to a G3X touch with EIS. This allowed me to remove the EDM-830. I always upload my engine data to Savvy, but I can’t figure out how. I am a ForeFlight pilot and I don’t use Garmin Pilot. I will appreciate any pointers! Thanks, Sheriff Sent from my iPhone using Tapatalk This thread from Van's has some suggestions: https://vansairforce.net/threads/garmin-g3x-touch-datalogs-download-and-management.192040/ Quote
PT20J Posted March 24 Report Posted March 24 G3X data logging must be enabled in configuration mode, and an SD card must be inserted in the G3X. The G3X will create a .csv file on the SD card every time it is powered up. You can copy the .csv files from the SD card to your computer and upload them to Savvy. I keep two SD cards for the G3X. I download nav data updates from flygarmin to a card and take it to the airplane and swap cards and then update the G3X. I copy the data files from the removed card to my computer and then reuse that card for the next nav data update. 1 Quote
Sheriff23 Posted March 24 Author Report Posted March 24 G3X data logging must be enabled in configuration mode, and an SD card must be inserted in the G3X. The G3X will create a .csv file on the SD card every time it is powered up. You can copy the .csv files from the SD card to your computer and upload them to Savvy. I keep two SD cards for the G3X. I download nav data updates from flygarmin to a card and take it to the airplane and swap cards and then update the G3X. I copy the data files from the removed card to my computer and then reuse that card for the next nav data update. PT20J thanks! I will do that on my next flight!Sent from my iPhone using Tapatalk Quote
