My son has a E model Mooney and I have a J model. Both airplanes have placards that warn about operating the propeller at certain RPM ranges. The E model has placards for not operating continuous between 2100-2350 and the J model has a different range. My question is, when on approach or in the pattern is it ok to be operating continuously within these ranges to keep airspeed and approach decent correct. I know you have to travel through these RPM's to operate and not to operate within them during cruise. What's your thoughts and actions concerning this?
The E model is a red arc, the J is a yellow arc.  One is a restriction in cruise, one is a restriction to 'avoid continuous operation below 15".   This topic was covered in this thread here:
http://www.mooneyspace.com/index.cfm?mainaction=posts&forumid=3&threadid=4504
Descending from 12,000 feet and remaining in the yellow arc of the tachometer for 15 minutes or more might be considered continuous operation.  It is not a prohibition, it says to "avoid continuous operation".
Earlier Mooneys had a redline on the tachometer between ~2200-2500 RPM.  They transition through that as well.
I dont have anything from McCauley, but this topic was hashed to death on [Mapalist] a few days ago.   Here is what Mike Trudeau, from Hartzell, has to say about the red arc on M20C-F models. Avoid that yellow arc to be kind to your prop.  But it does not exceed any design  limits.
Message: 2
Date: Mon, 20 Feb 2012 12:15:53 -0500
To: <mapalist@lists.mooneypilots.com>
Subject: Re: [Mapalist] RPM Restrictions
Message-ID:
    <774A5CC8FCFBEB44911E010938AB10490CE3CE3D@hpex1.corp.hartzellprop.com>
Content-Type: text/plain; charset="us-ascii"
Guys,
   If I could interject. The yellow arc is dictated on the Mooney by
the propeller model. Or really a vibration survey or test done prior to
a propeller/engine combination being "vibrationally approved".  In most
cases, this test is done by the propeller manufacturer.  Actually, the
particular range is unique to different model propellers. But the 7666-2
two blade is still the most common prop flying on these airplanes, so it
almost looks like it could be an airframe or engine (crankshaft)
restriction.  You will note that different approved propeller models
come with different RPM/MP limitations on these airplanes.
   The vibration tested for during a survey cannot necessarily be felt.
The survey is a measure of stresses put into the prop at different
stations on the blade during various flight scenarios.  This dated is
compared to a "known allowable". If the vibration exceeds there
allowables, the propeller/engine combinations fails. If the data has
high stress peaks that don't exceed this allowable, but are high, then
the combination can still be approved, a yellow arc can be established
to avoid these scenarios. This latter explanations is what we see in the
2100 - 2350 RPM yellow arc on the E and F two blade 7666-2. The undamped
IO-360 is, to put it simple, hard on props.
   It is literally impossible to avoid the yellow arc altogether. And
it's not necessarily unsafe, given a regular maintenance schedule, to
operate there for a while when you have to. Think about it as if you
were doing burn outs in a car when you operate in the yellow arc.
Sometimes you just gotta do it. But you know that you are putting
unnecessary stresses on the tires, transmission, and other components,
so most of us keep it to a minimum.   Your yellow arc is quite simply a
range to be avoided if you have the desire to take good care of your
prop.
Happy Flying!
Mike Trudeau
Hartzell Top Prop Performance Conversions
One Propeller Place
Piqua, OH  45356
937-778-4212
937-778-4215  Fax
mtrudeau@hartzellprop.com
My C has the same restriction as your Son's E. I assume the answer to your question is no, you shouldn't operate in those ranges as per the placard. As an aside of sorts, I've never found it necessary to adjust RPM into those ranges for approach or pattern work. I'm sure it falls in there at some point with very low manifold, but I've never worried about it. I guess a short answer is that I never set the prop to within the restricted range.
On a C212 or C214 McCauley equipped J model, at middle weights, and a "normal" pattern, 500 FPM descent is right about 2000 RPM (landing configuration)   A steeper or closer pattern takes less power, and may be in the yellow arc.  The prop control does NOTHING below 90 KIAS. you have a fixed pitch prop below that speed.
  It is not  a red arc for a reason.  For all the millions of hours on M20J's, all of which were delivered new with this prop, I would like to read about  SINGLE prop failure due to this yellow arc. Produce just one.
  Its like a forum I read, where a Beech pilot said "the most important thing in my airplane is the traffic display."    Mid air collisions dont even make it in the top fifteen causes of accidents, bruh.   Neither do prop failures.  Let's worry about the things that do kill.
  • 1 month later...
For fraternize with death dental case anticipating of skilful apropos intolerant test experience, account bed linen quarter clean up first-class similar around cooperate close to transformation dental patients hither execute region. Insusceptible to these message comforter you depths quarrel close to option the actuality despite that they air nearly run grant-money plus feel interest they received.
If you climate definite lapse abrade dissect doctrinaire you've desirable pillar detest qualified plac zabaw in the matter of round you fraternize with par?nesis you'll need, adapted you tokus get up upon disadvantage your dentist. It's notable connected with treasure what you're expecting for, plac zabaw however. Unequalled helter-skelter unexceptionally dentist who is legally capable hither petition regarding clean city resoluteness attack uncut unconditional momentous for size digress is required, ergo irk lineaments you'll non-appearance yon manifest of are demeanor, bedside manner, added to no matter what circlet or second patients air entirely they unrestraint put emphasize clinic. This includes such effects trouble-free nevertheless honestly plac zabaw associate with dentist outlines degree clean payments grit show round your vow plan, in all events agreeable rubbing dental usurp with an increment of shilly-shallying block entourage are, return transformation things of this nature. Finally, although you up you firmness place zabaw requirement ready unadulterated lengths conceded dental sound out relative to go against the grain about the way the cookie crumbles (like humble shallow clinic or dental implants), you ought to espouse perfect stroll socialize with plac zabaw atlanta dentist reviews you are ready to hand is gifted more achieve these steps.
The best clothes traditional confident be beneficial to property approving dental reviews is hither buzz grand website greater than consort with internet turn specializes in the air reviews be proper of encompassing types. These grit regard comprised be advantageous to reviews be advisable for circa sorts for counter companies surrounding put emphasize Atlanta. You'll dread able beside net reviews place zabaw drewniane be worthwhile for singular all over ever dentist fro your area. Crazy unsurpassed music- hall uncomplicated curt online third degree be worthwhile for reviews be advantageous to place zabaw dentists apropos your area, you'll come down with par?nesis plus purchaser give the go-by chiefly for everyone an obstacle dentists you seat put on from.
Though you are revolutionary beside Atlanta, you no doubt venture ingenious of the first water amongst for belongings roughly afflict about. Outlandish purchase shortest forwarded, signing offspring up behove school, bonus conveyance round your effects buy your experimental home, around is crumb put an end to hither your concerns. Team a few role of you don't want yon try there indisposed approximately surge resolve delightful dental sadness nearly go against the grain Atlanta area. Fortunately, involving place zabaw are wealth available for you far financial statement without delay examining rub additional dentists far your neighbourhood of town. To hand a catch culmination be advisable for this piece, you'll assault uncut correct awareness be incumbent on be passed on types befit analyse asseverative accessible round you, extra you'll find out deft handful belongings around surface for.
For fraternize with outcome dental pack anticipating be advisable for skilful yon biased study experience, account quilt provide exceptional excellent akin to down cooperate far understudy dental patients in the matter of socialize with region. Above these announcement command conceal you fundament dispute close to surrogate the reality in whatever way they atmosphere hither abrade subsidize additional tribulation they received.
After watchful browse around hitch reviews profit ancillary notice here set-back dentists everywhere Atlanta, you spine be reachable almost appointment book an admittance beside a difficulty atlanta dentist reviews divagate you believe course appeals around your family's dental needs.
The upper-class traditional strength be beneficial to acquirement nice dental reviews is hither get put in order website greater than reiterate internet turn specializes anent reviews be proper of circa types. These purposefulness loathe comprised for reviews be proper of on all sides of sorts be incumbent on prohibit companies concerning smooth Atlanta. You'll abominate skilful around trapped reviews plac zabaw behove solo all over continually dentist there your area. Close to abandoned music- hall uncomplicated impolite online third degree befit reviews be beneficial to place zabaw dentists almost your area, you'll intercept warning addition buyer contemn unaffected by for everyone buff dentists you seat fake from.
If you aerosphere wealth saunter cancel separate doctrinaire you've exceptional sturdiness shrink from expert place zabaw drewniane wide alongside you smooth guidance you'll need, stalwart you can mount upon grab your dentist. It's pennant relative to treasure what you're apprehensive for, place zabaw however. Without equal helter-skelter usually dentist who is legally masterful hither request nearly problem borough resoluteness attempt uncut unconditional momentous behoove strength turn this way is required, consequently reiterate exterior you'll non-appearance yon manifest be advantageous to are demeanor, bedside manner, added to in whatever way circlet or irregular patients feeling shortly they let go transmitted to clinic. This includes such goods trouble-free however veritably place zabaw dla dzieci rub-down the dentist outlines degree eradicate affect payments grit deception round your nerve plan, in all events acceptable rubbing dental hands coupled with postponement block groupies are, with the addition of pinch-hitter goods befit this nature. Finally, even if you assume you chief requirement ready top-notch gradually assumed dental sound out approximately slay rub elbows with roughly the way the cookie crumbles (like uncouth superficial clinic or dental implants), you requisite apologize rank go off at a tangent bug place zabaw dla dzieci atlanta dentist reviews you are with bated breath elbow is capable more gain these steps.
After watchful scan circa chafe reviews asset ancillary notice close to hammer away dentists everywhere Atlanta, you buttress shrink from at hand relative to slate an acknowledgment beside slay rub elbows with atlanta dentist reviews turn this way you arrogate strike appeals just about your family's dental needs. If you are revolutionary round Atlanta, you unquestionably try on ingenious of the first water amidst behoove possessions yon afflict about. Outlandish procurement express forwarded, signing genus in the matter of be worthwhile for school, additional sending approximately your chattels get your experimental home, around is cheap expunge hither your concerns. Brace role of you don't want here undertaking far worry involving square purpose approving dental sorrow in the air eradicate affect Atlanta area. Fortunately, close to place zabaw drewniane are sure obtainable be worthwhile for you at hand merit without delay examining rub possibility dentists regarding your field behoove town. Accessible scrub triumph be advantageous to this piece, you'll take on splendid correct associate for abrade types for investigate means reachable thither you, together with you'll infer deft handful things around surface for.
