crxcte Posted March 5, 2024 Report Posted March 5, 2024 Anyone know where I can get a used good condition exhaust tailpipe.
Ragsf15e Posted March 5, 2024 Report Posted March 5, 2024 53 minutes ago, crxcte said: Anyone know where I can get a used good condition exhaust tailpipe. Maybe @Alan Fox or Beagles?
N201MKTurbo Posted March 5, 2024 Report Posted March 5, 2024 Just send yours off for repair. They will most likely replace all the metal and return it to you. 2
Shadrach Posted March 5, 2024 Report Posted March 5, 2024 18 minutes ago, N201MKTurbo said: Just send yours off for repair. They will most likely replace all the metal and return it to you. Mine wore through at the elbow. No one would repair it. It was just over $400 new back in 07. I’d bet they’re near $1000 now.
N201MKTurbo Posted March 5, 2024 Report Posted March 5, 2024 Huh, the repair guys are not as bold as they once were.
Shadrach Posted March 5, 2024 Report Posted March 5, 2024 @crxcte This one was obviously involved in a gear up, but may be serviceable. https://www.texasairsalvage.com/main_view.php?editid1=288409
Shadrach Posted March 5, 2024 Report Posted March 5, 2024 6 minutes ago, N201MKTurbo said: Huh, the repair guys are not as bold as they once were. Indeed not. It was corroding from the inside out. Nevertheless, a new tube could have been welded to the “ball” but the shop said no one would touch it. I was naive then and rarely questioned what I was told…until I got the bill. They tried to charge 4hrs of shop time to hang that pipe.
crxcte Posted March 5, 2024 Author Report Posted March 5, 2024 15 hours ago, Shadrach said: @crxcte This one was obviously involved in a gear up, but may be serviceable. https://www.texasairsalvage.com/main_view.php?editid1=288409 That may work but they wanted ~$450 and may still need to go to the shop. A new one is looking like best bet. I was told mine was too far gone.
Shadrach Posted March 5, 2024 Report Posted March 5, 2024 40 minutes ago, crxcte said: That may work but they wanted ~$450 and may still need to go to the shop. A new one is looking like best bet. I was told mine was too far gone. Corrosion? $450 for a used, cosmetically damaged tai pipe is ridiculous when brand new ones can be had for <$800. Whoever is setting their pricing is clearly not concerned with converting inventory to cash.
crxcte Posted March 5, 2024 Author Report Posted March 5, 2024 Yes, after removing to take out for repair other cracks were seen. Looked like it had been repaired before.
MooneyMitch Posted March 6, 2024 Report Posted March 6, 2024 PM me please. I have a tailpipe from my former Mooney IO-360 A1A. This might help you. I'd attache a photo, but MS says I can't! I'll email a photo of it to you once I learn your address. Mitch
MooneyMitch Posted March 6, 2024 Report Posted March 6, 2024 14 hours ago, MooneyMitch said: PM me please. I have a tailpipe from my former Mooney IO-360 A1A. This might help you. I'd attache a photo, but MS says I can't! I'll email a photo of it to you once I learn your address. Mitch Whoops…. I’m incorrect. The tailpipe is off an O-360, not an IO-360. Sorry I couldn’t help you.
pagirard Posted March 6, 2024 Report Posted March 6, 2024 When the tail pipe of our 1974 M20E got corroded, I ordered a replacement at https://awi-ami.com/ I went back and forth with Tim over at AWI and he was super helpful to make sure I was ordering the right item: A630056-501 Since then I used them again for one of the exhaust riser that had a crack and can confirm, great company. Hope this helps
crxcte Posted March 6, 2024 Author Report Posted March 6, 2024 Made an order to Aerospace Welding Minneapolis with the same part number you listed. They had 4 in stock. I noticed Airplane Exhaust had the same part for $425, $300 less but none in stock otherwise I would of tried theirs.
Gee Bee Aeroproducts Posted March 8, 2024 Report Posted March 8, 2024 May I have the old ? I would mfg in titanium per sample i have done a few versions 1
