tcal780 Posted December 2, 2024 Author Report Posted December 2, 2024 12 hours ago, ragedracer1977 said: I believe that’s normal behavior on a no start and a bendix. The faster speed of the ring gear when the engine starts kicks the gear off. I’m not 100% on that, but I’d look into it before you spend money. The no start is almost assuredly a p lead issue. I’d triple check your key wiring. First thing I would do… key off - stay away from the prop! If you wired it backwards, the mags might be hot! Check if your p leads have continuity to ground. If they don’t, they’re hot. If they do, go turn the key to “on” or “run” and check continuity again. If they’re still grounded, it’s a wiring issue. I’ve seen 3 guys at the field with ignition switches wired incorrectly. Thanks for this. From what I've read, since the gear engages, the bendix drive is likely still good and needs a cleaning, unless the spring is shot. Either way, there's enough justification for me to replace it with a new one that also gives me 10lbs back of useable weight. Next opportunity I get, I'll check those connections at the ignition switch.
EricJ Posted December 6, 2024 Report Posted December 6, 2024 On 12/1/2024 at 10:04 PM, ragedracer1977 said: I believe that’s normal behavior on a no start and a bendix. The faster speed of the ring gear when the engine starts kicks the gear off. I’m not 100% on that, but I’d look into it before you spend money. That's correct. The starter motor spinning engages the starter gear with the ring, and the engine starting disengages it. If the starter was engaged and the engine hasn't started since, it would be expected that the starter gear would be engaged with the flywheel ring. Edit: This is for the stock starter. I think the SkyTec uses a solenoid that disengages the gear.
tcal780 Posted December 29, 2024 Author Report Posted December 29, 2024 I verified the ignition wiring was correct and the SOS is functioning properly. I also took the opportunity to replace the ignition harnesses which really needed to be done. Yesterday, I got the plane out of the hanger for another attempt and it fired right up! I don't think it took more than one revolution with the starter. My only conclusion is that I did not give it enough fuel on the last attempt. This time, I ran the boost pump with the throttle closed until the fuel flow showed 0GPH. Then, followed a normal, cold start procedure. Anyway, while the old starter was still serviceable, I'm super happy with the SkyTec and glad to have installed it. 1
Hank Posted December 29, 2024 Report Posted December 29, 2024 3 hours ago, tcal780 said: My only conclusion is that I did not give it enough fuel on the last attempt. This time, I ran the boost pump with the throttle closed until the fuel flow showed 0GPH. Then, followed a normal, cold start procedure. When cranking my 1970 C, after turning on the Master Switch, I run the fuel pump until fuel pressure stabilizes, then turn the pump off. Mixture rich, pump the throttle a few times (half a dozen or so in winter, once or twice in summer). When it's cold, fuel in the carb evaporates slower, so I'll wind and set the yoke clock and put on my headset before turning the key. She usually fires right up if preheated, but if not, hold the key and pump the throttle while cranking and it will fire.
Ventus4 Posted January 2, 2025 Report Posted January 2, 2025 Nice panel, Since I plan to do a very very similar work, do you have the cad (dxf or any other format) of the panel ? Thank you a lot. Andrea
tcal780 Posted January 2, 2025 Author Report Posted January 2, 2025 5 hours ago, Ventus4 said: Nice panel, Since I plan to do a very very similar work, do you have the cad (dxf or any other format) of the panel ? Thank you a lot. Andrea Unfortunately, all I have is a PDF proof that was provided to me for final approval. It's not to scale, but if it would help, let me know and I'd be happy to send it.
tcal780 Posted January 20, 2025 Author Report Posted January 20, 2025 Radios and audio panel installed and tested. Getting closer! 5
Hank Posted January 21, 2025 Report Posted January 21, 2025 On 1/19/2025 at 7:20 PM, tcal780 said: Radios and audio panel installed and tested. Getting closer! Wow! That looks great. But it would be difficult getting used to the switches and hear knob being down at the bottom . . .
tcal780 Posted January 22, 2025 Author Report Posted January 22, 2025 33 minutes ago, Hank said: Wow! That looks great. But it would be difficult getting used to the switches and hear knob being down at the bottom . . . Honestly, it'll probably take me more time to get used to the engine instruments being right in front of me.
Ventus4 Posted January 29, 2025 Report Posted January 29, 2025 Sorry for my late answer tcal, Thank you for the offer. Who made your panel ? I may contact them directly and ask. Thank you and compliment for the result. Andrea
tcal780 Posted January 29, 2025 Author Report Posted January 29, 2025 40 minutes ago, Ventus4 said: Sorry for my late answer tcal, Thank you for the offer. Who made your panel ? I may contact them directly and ask. Thank you and compliment for the result. Andrea No problem and thanks. Superior Aircraft Components out of Hutto,TX made the panel. They were great to work with and I would recommend them but I'd be surprised if they hand over any dwg files.
Sapphire1 Posted March 19, 2025 Report Posted March 19, 2025 Do you have the dimmer assembly wiring diagram by any chance? My dimmer circuit has an issue but we cant find a diagram for it. Thanks
tcal780 Posted March 19, 2025 Author Report Posted March 19, 2025 Sorry, I don't have a wiring diagram for the original dimmer assembly.
AndreiC Posted March 20, 2025 Report Posted March 20, 2025 3 hours ago, Sapphire1 said: Do you have the dimmer assembly wiring diagram by any chance? My dimmer circuit has an issue but we cant find a diagram for it. Thanks Are you looking for the original, factory dimmer electrical diagrams for a 1970 Mooney? I have them (there are two versions) somewhere, I can look them up.
Hank Posted March 20, 2025 Report Posted March 20, 2025 5 hours ago, Sapphire1 said: Do you have the dimmer assembly wiring diagram by any chance? My dimmer circuit has an issue but we cant find a diagram for it. Thanks 1 hour ago, AndreiC said: Are you looking for the original, factory dimmer electrical diagrams for a 1970 Mooney? I have them (there are two versions) somewhere, I can look them up. @Sapphire1, when the circuit board on mine blew, I had just come out of the clouds on a VOR-A approach over WV, and it caused a total electrical failure. My Mooney was down for several months because whatever blew up was completely gone, and no one could tell what it used to have been. I eventually managed to find a replacement board, but no idea what I'll do the next time. @AndreiC, can you post the drawings here? Or send them by PM, and shoot me a copy too. Thank you!
Sapphire1 Posted March 20, 2025 Report Posted March 20, 2025 I just lost lighting on engine instrument cluster, compass and overhead lighting. They were able to bypass the dimmer circuit to get the lights on, now they need to troubleshoot the dimmer control box. Maxwell states they repair them if my AP cant sort it out.
Sapphire1 Posted March 20, 2025 Report Posted March 20, 2025 13 hours ago, tcal780 said: Sorry, I don't have a wiring diagram for the original dimmer assembly. Thanks. I love your panel! 1
Sapphire1 Posted March 20, 2025 Report Posted March 20, 2025 9 hours ago, Hank said: @Sapphire1, when the circuit board on mine blew, I had just come out of the clouds on a VOR-A approach over WV, and it caused a total electrical failure. My Mooney was down for several months because whatever blew up was completely gone, and no one could tell what it used to have been. I eventually managed to find a replacement board, but no idea what I'll do the next time. @AndreiC, can you post the drawings here? Or send them by PM, and shoot me a copy too. Thank you! Thanks. I sent them to my A/P for review.
tcal780 Posted September 29, 2025 Author Report Posted September 29, 2025 It's a great feeling to get back in the air with this awesome panel and the new shiny stuff. My son and I spent a billion hours on it, but learned a TON. I need to fine tune the EDM900 fuel flow, engine HP%, and work out a few bugs with the interface between the GNX375 and the EDM900. The carb temp probe is also not working right. I still have the interior panels to put back in, too. Some of these panels are new replacements so they have to be trimmed, but that seems like a good job for January or February. For now, I'm just focused on getting familiarized with the new setup. First trip planned is to HHI in a couple weeks. 4
AJ88V Posted November 1, 2025 Report Posted November 1, 2025 New panel looks fantastic! On 9/9/2024 at 11:00 AM, tcal780 said: Superior made the panel. How much was the panel from Superior? Asking because I'm under the impression this alone is $4 - $5K. Also, what went into the decision to make a single panel vice multi-section panel? Thanks!
tcal780 Posted November 1, 2025 Author Report Posted November 1, 2025 Thanks 88V! The final invoice was $2500, but I spent probably $3k total because I ordered two sets of acrylic templates over the duration of the project. First, was a two piece set based on the original L&R panels. Then, I pivoted to a one piece design, made some instrument placement adjustments, and asked for the second acrylic template to be sent for final fitment and markup. As mentioned above, the original plan was to go with a two piece, but I ended up changing to a one piece for few reasons: 1) The original radio rack rails (which are also the center panel supports) were turned into swiss cheese from all the alterations over the years and I did not want to remake them. Superior could rivet new radio rails right to the panel, which is what I did. 2) The location of the original supports restricted available space on the left and thus, less flexibility to design a clean layout. I recall struggling to keep the EDM900 there while keeping the G5's centered on the yoke while working on the two piece layout. Plus, I had contemplated flush mounting the G5's and the EDM which would have required more space for those instruments, exacerbating the problem. Ultimately, I ended up choosing the panel mountings 3) Simply, the one piece reduced overall complexity. Your impression of 4-5k is probably in line with a panel that includes their premium labeling/graphic options that could easily push the cost to 4-5k, but those weren't for me. I just elected for the simple gray with white labeling. Tcal
