PierreL Posted August 18, 2023 Report Posted August 18, 2023 Hello all, I am looking for an airspeed safety switch for a 1989 M20J and after contacting some Mooney service centers and Lasar it seems a bit tricky. Reference is 880013-507. Let me know which companies could supply these parts or if anyone knows an equivalent? Many Thanks
47U Posted August 18, 2023 Report Posted August 18, 2023 9 minutes ago, PierreL said: I am looking for an airspeed safety switch for a 1989 M20J and after contacting some Mooney service centers and Lasar it seems a bit tricky. Reference is 880013-507. Found one on controller.com… but it’s in Germany.
PierreL Posted August 18, 2023 Author Report Posted August 18, 2023 17 minutes ago, 47U said: Found one on controller.com… but it’s in Germany. Many thanks I will contact them if I cannot find it in the US.
PierreL Posted August 18, 2023 Author Report Posted August 18, 2023 2 hours ago, haymak3r said: I think this is what you're after: VEP V21614 drawing indicates Mooney P/N 880013-505 The one I am looking for is 880013-507. So I am not sure it is compatible.
haymak3r Posted August 18, 2023 Report Posted August 18, 2023 agreed. Was hoping that link would get you to where you can find the right one though. Good luck.
KSMooniac Posted August 18, 2023 Report Posted August 18, 2023 My J uses a squat switch on the MLG instead of the airspeed switch, but many years ago I added a generic TCW airspeed switch to trigger a hobbs meter to record flight time. It works great, was relatively inexpensive, and could probably be adapted to replace the unobtanium Mooney switch under VARMA.
Fly Boomer Posted August 18, 2023 Report Posted August 18, 2023 2 hours ago, 201Mooniac said: Seems like a great use for VARMA Has anyone expended the time and effort required for VARMA, and actually received a VARMA letter?
KSMooniac Posted August 18, 2023 Report Posted August 18, 2023 I half-watched an EAA webinar on Wednesday evening on the topic, but haven't tried it myself yet. I would encourage every owner to go watch it as I believe they're archived, and count for WINGS credit in case that is useful for anyone. I believe it was developed for exactly this type of situation.
PT20J Posted August 18, 2023 Report Posted August 18, 2023 5 hours ago, PierreL said: after contacting some Mooney service centers and Lasar it seems a bit tricky. Define "tricky."
PierreL Posted August 18, 2023 Author Report Posted August 18, 2023 9 minutes ago, PT20J said: Define "tricky." Difficult to find
Ragsf15e Posted August 18, 2023 Report Posted August 18, 2023 (edited) 5 minutes ago, PierreL said: Difficult to find It’s one of the parts that scares me about my Mooney. Even with the factory making parts, there are a few things that seem to be unobtainable… new gears for the dukes electric gear, airspeed switches, etc. I thought there was a way to take the asss apart and replace the seals though, no? Edited August 18, 2023 by Ragsf15e
PT20J Posted August 18, 2023 Report Posted August 18, 2023 1 minute ago, PierreL said: Difficult to find The IPC pdf has the following comment: S/N 24-0001 thru 24-1685 order 880013-505 (All earlier 14V) S/N 24-1686 thru 24-TBA order 880013-507 (later 14V and All 28V) I would contact Frank Crawford at Mooney and ask about the difference (he maintains the IPCs and wrote the comment). I'm pretty sure VEP made both of the switches. Frank might be willing to cross reverence the VEP part number for the -507 if the -505 won't work. fcrawford@mooney.com (830)792-2920 2
PierreL Posted August 18, 2023 Author Report Posted August 18, 2023 32 minutes ago, PT20J said: The IPC pdf has the following comment: S/N 24-0001 thru 24-1685 order 880013-505 (All earlier 14V) S/N 24-1686 thru 24-TBA order 880013-507 (later 14V and All 28V) I would contact Frank Crawford at Mooney and ask about the difference (he maintains the IPCs and wrote the comment). I'm pretty sure VEP made both of the switches. Frank might be willing to cross reverence the VEP part number for the -507 if the -505 won't work. fcrawford@mooney.com (830)792-2920 Many thanks I just send him an email
Larry Posted August 18, 2023 Report Posted August 18, 2023 Wasn't Don Maxwell replacing the diaphragm on the Airspeed Safety Switches? It may be worth a call. 1
Fly Boomer Posted August 18, 2023 Report Posted August 18, 2023 3 hours ago, PT20J said: The IPC pdf has the following comment: S/N 24-0001 thru 24-1685 order 880013-505 (All earlier 14V) S/N 24-1686 thru 24-TBA order 880013-507 (later 14V and All 28V) I would contact Frank Crawford at Mooney and ask about the difference (he maintains the IPCs and wrote the comment). I'm pretty sure VEP made both of the switches. Frank might be willing to cross reverence the VEP part number for the -507 if the -505 won't work. fcrawford@mooney.com (830)792-2920 FWIW the K-model IPC says 2- 52 880013-503 .SWITCH, AIRSPEED SAFETY V/ 1 2- 52 880013-507 .SWITCH, AIRSPEED SAFETY VI/ 1 and under EFFECTIVITIES V 25-0001 THRU 25-0446 VI 25-0447 THRU 25-TBA Could it be that the 507 was just a version of the switch that could run from 10-30 volts?
PT20J Posted August 18, 2023 Report Posted August 18, 2023 12 minutes ago, Fly Boomer said: FWIW the K-model IPC says 2- 52 880013-503 .SWITCH, AIRSPEED SAFETY V/ 1 2- 52 880013-507 .SWITCH, AIRSPEED SAFETY VI/ 1 and under EFFECTIVITIES V 25-0001 THRU 25-0446 VI 25-0447 THRU 25-TBA Could it be that the 507 was just a version of the switch that could run from 10-30 volts? I don't know what the difference is but I doubt it has anything to do with the bus voltage. The voltage spec on switches is related to arcing which shouldn't be an issue at these low voltages.
Fly Boomer Posted August 18, 2023 Report Posted August 18, 2023 2 minutes ago, PT20J said: I don't know what the difference is but I doubt it has anything to do with the bus voltage. The voltage spec on switches is related to arcing which shouldn't be an issue at these low voltages. The specifications for one of their switches is 10-30 volts. It made me wonder if there were low-voltage-only switches in the past.
1980Mooney Posted August 20, 2023 Report Posted August 20, 2023 (edited) On 8/18/2023 at 6:43 PM, PT20J said: I don't know what the difference is but I doubt it has anything to do with the bus voltage. The voltage spec on switches is related to arcing which shouldn't be an issue at these low voltages. Correct. The difference is in the "Increasing Pressure" and the "Decreasing Pressure" settings of the switch. It looks like the same switch just with different calibration. Both switches are rated for 10-30 volts. DC. 880013-505 Increasing Pressure = 2.8 +/- 0.4 " H20 Decreasing Pressure = > 1.4" H2O 880013-507 Increasing Pressure = 2.4 +/- 0.4 " H20 Decreasing Pressure = > 1.6" H2O Edited August 20, 2023 by 1980Mooney 1
PT20J Posted August 20, 2023 Report Posted August 20, 2023 On 8/18/2023 at 6:47 AM, PierreL said: Hello all, I am looking for an airspeed safety switch for a 1989 M20J and after contacting some Mooney service centers and Lasar it seems a bit tricky. Reference is 880013-507. Let me know which companies could supply these parts or if anyone knows an equivalent? Many Thanks Do you know if the problem is the diaphragm or the microswitch? These units have two microswitches. One is used for the gear and the other is for a flight timer or some other accessory that is often not installed. If the microswitch is bad, you might be able to just switch the landing gear circuit to the other switch. 3
PierreL Posted August 20, 2023 Author Report Posted August 20, 2023 12 hours ago, 1980Mooney said: Correct. The difference is in the "Increasing Pressure" and the "Decreasing Pressure" settings of the switch. It looks like the same switch just with different calibration. Both switches are rated for 10-30 volts. DC. 880013-505 Increasing Pressure = 2.8 +/- 0.4 " H20 Decreasing Pressure = > 1.4" H2O 880013-507 Increasing Pressure = 2.4 +/- 0.4 " H20 Decreasing Pressure = > 1.6" H2O Many thanks. looks like VEP reference for 880013-507 is 656-3. I will contact world magnetics asking for this reference.
PierreL Posted August 20, 2023 Author Report Posted August 20, 2023 11 hours ago, PT20J said: Do you know if the problem is the diaphragm or the microswitch? These units have two microswitches. One is used for the gear and the other is for a flight timer or some other accessory that is often not installed. If the microswitch is bad, you might be able to just switch the landing gear circuit to the other switch. Thank you PT20J. i have seen this microswitch swap method on Mooneyspace. I will try it at next visit. If the problem comes from the diaphragm or the seal it seems more difficult to fix.
DCarlton Posted August 20, 2023 Report Posted August 20, 2023 (edited) My airspeed safety switch stuck a few years ago. We were able to remove it, remove the center screw I think, put a drop of mouse milk (I think) in it , and get it working on the bench. Reinstalled and it's worked fine ever since (long enough for me to forget the details). Have no idea if opening the switch creates a paper trail problem, but we got it working. Might be worth a try. Then there's the $$$$ World Magnetics option... Edited August 20, 2023 by DCarlton
PT20J Posted August 20, 2023 Report Posted August 20, 2023 10 minutes ago, DCarlton said: My airspeed safety switch stuck a few years ago. We were able to remove it, remove the center screw I think, put a drop of mouse milk (I think) in it , and get it working on the bench. Reinstalled and it's worked fine ever since (long enough for me to forget the details). Have no idea if opening the switch creates a paper trail problem, but we got it working. Might be worth a try. Then there's the $$$$ World Magnetics option... Are you saying you removed the cap and accessed the microswitches, or the large screw on the other side? The large screw adjusts the spring tension to set the calibration. https://www.knr-inc.com/shop-talk-articles.html?view=article&id=93&catid=25 1
