ArrowBerry Posted May 25, 2023 Report Posted May 25, 2023 Hartzell HC-C2YR-1BF propeller, we found this on the post flight walk around. Clearly the spinner has been stop drilled already, and that middle piece broke off in flight today. I’ve looked at Hartzell’s website and application guide, where else is a good source for a new spinner? Do you also have to replace the back plate? Quote
Fly Boomer Posted May 25, 2023 Report Posted May 25, 2023 2 minutes ago, ArrowBerry said: Hartzell HC-C2YR-1BF propeller, we found this on the post flight walk around. Clearly the spinner has been stop drilled already, and that middle piece broke off in flight today. I’ve looked at Hartzell’s website and application guide, where else is a good source for a new spinner? Do you also have to replace the back plate? Always good to check with Cody Stallings for used parts @Cody Stallings. Cody is our resident prop guy. Quote
ArrowBerry Posted May 25, 2023 Author Report Posted May 25, 2023 Ours is a 67E, would the spinner off of a 67F be the same if it has the same model of propeller? Quote
MikeOH Posted May 25, 2023 Report Posted May 25, 2023 Sorry I can't help with a new spinner. I did notice, however, that most of the visible screws are missing the nylon washers; hard to tell for certain. Anyway, they are designed to be there and help reduce stress and vibration on the spinner. You might consider installing with them when you replace the spinner. Aircraft Spruce: https://www.aircraftspruce.com/catalog/hapages/hanylonwashers.php?clickkey=161389 Quote
ArrowBerry Posted May 26, 2023 Author Report Posted May 26, 2023 2 hours ago, MikeOH said: Sorry I can't help with a new spinner. I did notice, however, that most of the visible screws are missing the nylon washers; hard to tell for certain. Anyway, they are designed to be there and help reduce stress and vibration on the spinner. You might consider installing with them when you replace the spinner. Aircraft Spruce: https://www.aircraftspruce.com/catalog/hapages/hanylonwashers.php?clickkey=161389 Good catch, thanks for pointing that out. They did have nylon washers but in poor shape, we'll definitely be replacing those. Quote
ArrowBerry Posted May 26, 2023 Author Report Posted May 26, 2023 Thanks everyone for the input. I've ordered a used one off eBay... now the wait! Quote
Mooneyintn Posted June 24, 2023 Report Posted June 24, 2023 I have a good used one with the ears. Quote
