hais Posted April 29, 2023 Author Report Posted April 29, 2023 13 hours ago, GeeBee said: but our equipment in GA and training make them unavailable. I took the opportunity to consult https://www.faa.gov/documentLibrary/media/Advisory_Circular/AC_90-101A_CHG_1.pdf Looks like we'll never have this capability: dual FMS, dual autopilots, dual ADS, and IRU ... But then again, did we not debate no one will ever upgrade to glass...?
GeeBee Posted April 29, 2023 Report Posted April 29, 2023 1 hour ago, ilovecornfields said: But, technically, is there an Equadorian air regulation that specifically forbids me from “flying the approach” while being towed behind a jet? ;-) Yes, because the tether will swing you outside the RNP. 1
GeeBee Posted April 29, 2023 Report Posted April 29, 2023 16 minutes ago, hais said: I took the opportunity to consult https://www.faa.gov/documentLibrary/media/Advisory_Circular/AC_90-101A_CHG_1.pdf Looks like we'll never have this capability: dual FMS, dual autopilots, dual ADS, and IRU ... But then again, did we not debate no one will ever upgrade to glass...? You can also add EGPWS too
GeeBee Posted May 1, 2023 Report Posted May 1, 2023 On 4/28/2023 at 8:44 PM, ilovecornfields said: But, technically, is there an Equadorian air regulation that specifically forbids me from “flying the approach” while being towed behind a jet? ;-) Here is your solution! 2
rbp Posted May 1, 2023 Report Posted May 1, 2023 in air "refueling" for gliders! fo course the tow vehicle has to be in a descent
ilovecornfields Posted May 2, 2023 Report Posted May 2, 2023 10 hours ago, GeeBee said: Here is your solution! That’s a cool video but isn’t the “zero emission” flight only true for one of those aircraft?
GeeBee Posted May 2, 2023 Report Posted May 2, 2023 9 hours ago, ilovecornfields said: That’s a cool video but isn’t the “zero emission” flight only true for one of those aircraft? There is no such thing a zero emission anything.
EricJ Posted May 6, 2023 Report Posted May 6, 2023 On 5/2/2023 at 4:51 AM, GeeBee said: There is no such thing a zero emission anything. Photons.
GeeBee Posted May 6, 2023 Report Posted May 6, 2023 7 hours ago, EricJ said: Photons. True by themselves, but man can create them without emissions.
carusoam Posted May 8, 2023 Report Posted May 8, 2023 Ever compare the flight track of your plane following an analog VOR course…. Over a chart with straight lines …? Then compare that to the flight track of your plane following the GPS course… The standard width of Victor skyways is based on the accuracy of the analog system’s scalloped shapes….. We sometimes have to switch between using the VOR at the beginning of the pair to the one at the end, near the half way point…. (As charted) This is done because the plane will follow the scalloped shape outside the standard width of the Victor skyway…. Are we discussing the same thing? Best regards, -a-
