GeeBee Posted April 7, 2023 Report Posted April 7, 2023 I have A and C at every seat. Everyone is happy. If I need two Cs at a single seat, I have A to C adapters in the seat back. No problems and everyone is happy. I have A to Lightening, A to C and C to C cables. No problems, everyone should be happy...and they are. Quote
Pinecone Posted April 8, 2023 Report Posted April 8, 2023 3 hours ago, Fly Boomer said: Is there another box or wall-wart to run the O2D2 from USB? And if you do that, do you remove the batteries? No, the MC clock has two ports. The newer O2D2 you can leave the batteries in, and if the cords comes out of the power stops, it will run off the batteries. Older ones are different. Quote
Fly Boomer Posted April 8, 2023 Report Posted April 8, 2023 35 minutes ago, Pinecone said: No, the MC clock has two ports. The newer O2D2 you can leave the batteries in, and if the cords comes out of the power stops, it will run off the batteries. Older ones are different. Mine is older. I'll have to research further. Quote
EricJ Posted April 9, 2023 Report Posted April 9, 2023 On 4/7/2023 at 6:15 AM, Pinecone said: My plane came with a MidContinent digital clock with 2x USB-A ports. I might consider replacing it with their version with 1 - USB-A and 1 - USB-C. Or just keep it and add USB-C panel mount power device. This one is TSO'd and has the same current capability (3.0A) for both the USB-C and USB-A ports. The only difference appears to be the mechanical form factor of the plug. https://www.aircraftspruce.com/catalog/elpages/stratuspowerpro11-18449.php Quote
carusoam Posted April 9, 2023 Report Posted April 9, 2023 Eric, That looks like the guts can be swapped out for the next standard when it arrives…. My biggest hold from installing plugs in my panel… is having it become defunct in a year or two… Thanks for supplying all the phone technology answers!!! Best regards, -a- Quote
EricJ Posted April 9, 2023 Report Posted April 9, 2023 31 minutes ago, carusoam said: Eric, That looks like the guts can be swapped out for the next standard when it arrives…. My biggest hold from installing plugs in my panel… is having it become defunct in a year or two… Thanks for supplying all the phone technology answers!!! Best regards, -a- I think that's why the cigar-lighter-plug-in options are popular. They can be swapped out really easily on demand at low cost. This one looks reasonably future-proof for a while: https://www.amazon.com/Syncwire-Charger-Adapter-Cigarette-Compatible/dp/B08W1SVT1L 1 Quote
Pinecone Posted April 9, 2023 Report Posted April 9, 2023 8 hours ago, EricJ said: This one is TSO'd and has the same current capability (3.0A) for both the USB-C and USB-A ports. The only difference appears to be the mechanical form factor of the plug. https://www.aircraftspruce.com/catalog/elpages/stratuspowerpro11-18449.php What I would like to find is dual USB-C Smart outlets. Since I already have two USB-A on pilot side. That would be great for pax side. Quote
rbp Posted April 9, 2023 Author Report Posted April 9, 2023 5 hours ago, Pinecone said: USB-C Smart outlets smart how? Quote
Pinecone Posted April 10, 2023 Report Posted April 10, 2023 Communicates with device and negotiates the charge rate. You can get dumb USB-C that is the same as USB-A with a different connector. 2 Quote
rbp Posted April 11, 2023 Author Report Posted April 11, 2023 On 4/10/2023 at 8:14 AM, Pinecone said: Communicates with device and negotiates the charge rate. You can get dumb USB-C that is the same as USB-A with a different connector. yes, I mentioned that. its called "USB Power Delivery" Quote
