Dsolly Posted November 4, 2022 Report Posted November 4, 2022 Purchased new engine for my M20J and kept this magneto off old engine. Removed 6/2021 and had less than 50 hrs on this overhauled magneto. Magneto was rebuilt Nov 2020. Was overhauled by Quality Aircraft Accessories. Asking $1800.00 plus shipping
Dsolly Posted November 5, 2022 Author Report Posted November 5, 2022 No I didn't but perhaps I should had. The new engine required a different mag. The old engine was a IO-360 A3B6D and the replacement is a IO-360A3B6. The ending D designates a different mag which is better because the new mag has two independent connectors out of the engine. I am not very technical, so I probably didn't explain correctly.
KSMooniac Posted November 5, 2022 Report Posted November 5, 2022 No, you made a wise decision to trade for the A3B6 and ditch the A3B6D. You now have the option to replace one of the independent mags with a single electronic ignition and retain one of the simple mags if you wish. I still have the A3B6D and will be installing the Electroair electronic dual replacement fairly soon. There is only one option for the D engine currently. 2
gevertex Posted November 6, 2022 Report Posted November 6, 2022 7 hours ago, KSMooniac said: No, you made a wise decision to trade for the A3B6 and ditch the A3B6D. You now have the option to replace one of the independent mags with a single electronic ignition and retain one of the simple mags if you wish. I still have the A3B6D and will be installing the Electroair electronic dual replacement fairly soon. There is only one option for the D engine currently. Any PIREPs on the Electroair mag? I was looking at that one also for the future.
carusoam Posted November 7, 2022 Report Posted November 7, 2022 On 11/5/2022 at 8:40 PM, gevertex said: Any PIREPs on the Electroair mag? I was looking at that one also for the future. Yes, there are at least two pireps… Probably a solid reason why there aren’t many more like the other supplier…. It Will probably take somebody with Scott’s experience to make ElectroAire work for a Mooney…. I believe the end result were returns to the vendor… one was for an Ovation in Brazil… Best regards, -a-
KSMooniac Posted November 7, 2022 Report Posted November 7, 2022 I've seen a couple of positive reports on Electroair's FB page... of course they could filter out any bad ones, but I believe it to be a good product and am willing to put my money behind it for my plane. I don't know how those folks got it flying...I think they must be all-electric and have a second alternator to get it approved, but I'm not sure. I'm not ready to go all-electric, so I still have a vacuum pump on the accessory case where eventually I want the B&C Alternator, so for my installation I'll need to dedicated backup battery that only powers the EIS. I thought it was "finished" but I still haven't seen my order finalized, so perhaps not. 1
gevertex Posted November 24, 2022 Report Posted November 24, 2022 On 11/6/2022 at 8:45 PM, carusoam said: Yes, there are at least two pireps… Probably a solid reason why there aren’t many more like the other supplier…. It Will probably take somebody with Scott’s experience to make ElectroAire work for a Mooney…. I believe the end result were returns to the vendor… one was for an Ovation in Brazil… Best regards, -a- Are their other options for electric ignition on dual mag engines?
skykrawler Posted November 25, 2022 Report Posted November 25, 2022 I don't understand why ElectroAire didn't get the impulse ring electronic ignition certified to work with the D mag. Just disable the one side of the D mag with the p-lead.
gtprend Posted February 17, 2023 Report Posted February 17, 2023 Not sure, considering this as a backup. Did you sell it?
KSMooniac Posted February 17, 2023 Report Posted February 17, 2023 My Electroair kit arrives on Monday! Installation not scheduled yet... a slot for cowl repair and full re-paint might open before I get a chance to install it.
N201MKTurbo Posted February 17, 2023 Report Posted February 17, 2023 On 11/25/2022 at 5:17 AM, skykrawler said: I don't understand why ElectroAire didn't get the impulse ring electronic ignition certified to work with the D mag. Just disable the one side of the D mag with the p-lead. I bet with an adapter, you could mount a regular mag on the D engine.
KSMooniac Posted February 20, 2023 Report Posted February 20, 2023 9 hours ago, Evan said: Are you going with the backup alternator or battery? Backup battery... I still have a vacuum pump and there is not an STC backup alternator for our engines that I know of. Eventually I'd like to add it with a panel update/all-electric.
KSMooniac Posted February 20, 2023 Report Posted February 20, 2023 4 hours ago, Evan said: This is great news. Last I heard, the battery wasn't approved yet... sounds like it is. Might have to give them a call to order! The alternator, if you've removed the vacuum pump, is a field approval from a local FSDO. There are a couple of other Mooneys flying around that had this done. Agreed... if I were able today I would pursue that route, but I'm still rockin' the vacuum pump and gyros. I have no schedule for going all-electric but at least I can upgrade the ignition sooner rather than later.
Rotorhead Posted March 26, 2023 Report Posted March 26, 2023 Does anyone by chance know the shelf life of the batteries?
carusoam Posted March 26, 2023 Report Posted March 26, 2023 30 minutes ago, Rotorhead said: Does anyone by chance know the shelf life of the batteries? Which batteries are we discussing? Main aircraft batteries like a sealed Concorde 24V for the Ovation… 6years when used for VFR flight… The old style wet lead/acid Gill battery would only go 2years… Capacity test them annually if flying in IMC… everything gets one step more serious when flying in IMC… Or are we discussing a specific battery for the electronic mag? Best regards, -a-
Rotorhead Posted March 26, 2023 Report Posted March 26, 2023 47 minutes ago, carusoam said: Which batteries are we discussing? Main aircraft batteries like a sealed Concorde 24V for the Ovation… 6years when used for VFR flight… The old style wet lead/acid Gill battery would only go 2years… Capacity test them annually if flying in IMC… everything gets one step more serious when flying in IMC… Or are we discussing a specific battery for the electronic mag? Best regards, -a- Referring to the backup batteries for the dual mag EIS. (IBBS-12v-3ah-CRT) -KC 1
Kirch56H Posted March 27, 2023 Report Posted March 27, 2023 7 hours ago, Rotorhead said: Referring to the backup batteries for the dual mag EIS. (IBBS-12v-3ah-CRT) -KC looks like they are 7 years. Per the TCW site, you can replace the cells for a few hundred dollars. 1
RV-6 Posted August 9, 2023 Report Posted August 9, 2023 To Dsolly, do you still have that Dual mag available you pulled off your M20J ?
Fly Boomer Posted August 9, 2023 Report Posted August 9, 2023 11 hours ago, RV-6 said: To Dsolly, do you still have that Dual mag available you pulled off your M20J ? Welcome to MooneySpace. On this forum, to get someone's attention, you either quote them by selecting some text and then hitting the "Quote Selection" button that pops up, or you can directly reference their screen name with the "at sign" like this @Dsolly. In any event the offer on that mag was close to a year ago, and Dsolly's last visit to this forum was about 6 months ago, so unless he logs on again, he may not see your message.
Alan Fox Posted August 9, 2023 Report Posted August 9, 2023 2 hours ago, Fly Boomer said: Welcome to MooneySpace. On this forum, to get someone's attention, you either quote them by selecting some text and then hitting the "Quote Selection" button that pops up, or you can directly reference their screen name with the "at sign" like this @Dsolly. In any event the offer on that mag was close to a year ago, and Dsolly's last visit to this forum was about 6 months ago, so unless he logs on again, he may not see your message. Boomer , I have one , but no paperwork ... 856 419 5209
Fly Boomer Posted August 9, 2023 Report Posted August 9, 2023 @RV-6 see above for an offer from a well known and respected parts and accessories guy.
