Rotorhead Posted September 10, 2022 Report Posted September 10, 2022 Basically no matter the power setting, vacuum gauge is unreliable and the arrow is rapid/ erratic sometimes spinning all the way around the sight glass. Seems to kind of stay within 4-6 at higher power but will start to spin again with No reason. No low vac annunciators and all instruments seen to be working as should be. Initial look under the glareshielf doesn't show signs of leaks. Anyone seen this before? Quote
carusoam Posted September 10, 2022 Report Posted September 10, 2022 Got a video of that? Sounds like a simple sensor/gauge/tube failure… if you don’t get a low vac or high vac light to go with that… Our dry vac pumps are very digital… they either work or don’t work… They work up until a vane breaks… Best regards, -a- Quote
Rotorhead Posted September 10, 2022 Author Report Posted September 10, 2022 (edited) @carusoam figured out to use a 3rd party server. https://photos.app.goo.gl/6wTkTT4XJUZ9vRr5A Edited September 10, 2022 by Rotorhead 1 Quote
carusoam Posted September 14, 2022 Report Posted September 14, 2022 On 9/10/2022 at 11:31 AM, Rotorhead said: @carusoam figured out to use a 3rd party server. https://photos.app.goo.gl/6wTkTT4XJUZ9vRr5A Great work Rh! Just as you described. I didn’t that could happen, without the needle just falling off… Thanks for linking the video here… Now, to find somebody familiar with these things…. Best regards, -a- Quote
carusoam Posted September 14, 2022 Report Posted September 14, 2022 @Rotorhead i looked up UMA vac gauges to see if they had a troubleshooting guide… They have a trouble shooting sentence…. Best regards, -a- Troubleshooting inaccurate Readings: 1.) If gauge is reading erratic first check filters in system, if clean and all lines are open and not leaking, connect a vacuum pump into the system to check instrument operation with a known vacuum source. gyroSuction3-200-12.pdf Quote
