201er Posted May 23, 2022 Report Posted May 23, 2022 @KSMooniac recently set some pretty tight attachment space limits, but can't even find a way to delete old attachments to make space. So I figured out that if I go to the top right bar, click my username and select "My Attachments" I can go to a page that lists all of them. I can even click a box to "select all" or hit checkmarks to select a bunch. So far so good. Should be easy enough to delete a bunch quickly this way. But where's the delete button!? Can't even post a screenshot of the page because I'm out of attachment space. 1 Quote
Fly Boomer Posted May 23, 2022 Report Posted May 23, 2022 I doubt @KSMooniac can help. When you select one or more attachments, you should see a pop-up at the bottom of your screen with a trash can on it. Try clicking that (I have not tried it). 1 Quote
201er Posted May 23, 2022 Author Report Posted May 23, 2022 Ok, this gets even dumber. I finally found the button. It's behind the ads on the bottom of the page. You have to click a tiny down arrow in the lower left corner to shrink the ad to reveal the delete button behind that. So, I started deleting a bunch of pictures... and then I found out that deleting deleted pictures also frees up my quota! Darn, already deleted a bunch of active stuff but turns out deleting already deleted stuff also frees up space. You can select all or set checkmarks on a bunch of attachments and then minimize the ad and click the delete button behind it. Fairly quick. Start by deleting all the deleted attachments before deleting any active ones. Quote
Fly Boomer Posted May 23, 2022 Report Posted May 23, 2022 1 hour ago, 201er said: I finally found the button. It's behind the ads on the bottom of the page I'm not seeing the adverts. Quote
KSMooniac Posted May 23, 2022 Report Posted May 23, 2022 I'm confused? I don't have anything to do with admin stuff here. Sent from my LM-V405 using Tapatalk Quote
LANCECASPER Posted May 23, 2022 Report Posted May 23, 2022 29 minutes ago, KSMooniac said: I'm confused? I don't have anything to do with admin stuff here. Sent from my LM-V405 using Tapatalk I think @201er is confusing you with @mooniac58 1 1 Quote
LANCECASPER Posted May 23, 2022 Report Posted May 23, 2022 2 hours ago, Fly Boomer said: I'm not seeing the adverts. You are a supporter. You only see ads if you haven't donated to support the site. Quote
Fly Boomer Posted May 23, 2022 Report Posted May 23, 2022 10 minutes ago, LANCECASPER said: You are a supporter. You only see ads if you haven't donated to support the site. I see. Quote
Shadrach Posted May 23, 2022 Report Posted May 23, 2022 41 minutes ago, Fly Boomer said: I see. or rather you don't see... 1 Quote
Shadrach Posted May 23, 2022 Report Posted May 23, 2022 1 hour ago, KSMooniac said: I'm confused? I don't have anything to do with admin stuff here. Sent from my LM-V405 using Tapatalk Pretty sure that you're not the one who is confused! 2 Quote
201er Posted May 23, 2022 Author Report Posted May 23, 2022 1 hour ago, LANCECASPER said: I think @201er is confusing you with @mooniac58 Sorry, you’re right. I meant @mooniac58 Quote
