Bobaran Posted May 22, 2022 Report Posted May 22, 2022 I need to remove a brake caliper on my 67 m20f and need step by step instructions. Thanks Quote
EricJ Posted May 22, 2022 Report Posted May 22, 2022 17 minutes ago, Bobaran said: I need to remove a brake caliper on my 67 m20f and need step by step instructions. Thanks There is likely a maintenance manual for your airplane available online, or perhaps here in the downloads. That'll have instructions. Quote
N201MKTurbo Posted May 22, 2022 Report Posted May 22, 2022 I would go to the Cleveland website. They will have the exploded view of all the brake parts. in a nutshell, remove the two 7/16 bolts that hold the fixed brake pad to the caliper, remove that pad and slide the caliper off the two support posts. 1 Quote
Guest Posted May 22, 2022 Report Posted May 22, 2022 When looking at the caliper, you’ll see two bolts and two nuts. Don’t take the nuts off, they hold the pins in place. The two bolts may or may not have safety wire, if they’re wires, cut the wire and remove the bolts, this will allow the inner brake pad to fall off, wiggle the caliper off. Clarence Quote
Bobaran Posted May 22, 2022 Author Report Posted May 22, 2022 Thanks guys. This is extremely helpful and answers my question perfectly. Quote
Yetti Posted May 24, 2022 Report Posted May 24, 2022 Here's the tricky part. You can't remove the calipers if you are removing the calipers. You'll need an A&P for that. Now if you are changing the tire. No problem just remove the calipers. 1 Quote
