Dotto Posted May 2, 2021 Report Posted May 2, 2021 Hi all. I found straight stemmed inner tubes on my new to me 1962 M20C. I saw that others had questions on stem angles prior to me replacing mine so I attached the photos of the straight and 70* stems.
RLCarter Posted May 2, 2021 Report Posted May 2, 2021 Yep, there was a discussion on these a few months back. The straight rubber stems fail doe to being in a constant bind, 90° metal stem set too close the wheel. Both make it a PITA to service, 70° stems solves these issues.
Jim Peace Posted May 2, 2021 Report Posted May 2, 2021 OMGosh.... I had to deal with this today. My plane was brought to the Mooney guru of Florida for its annual. I asked for new tires all around. I got the tires but not the tubes I wanted. I went to pick up my plane and the nose tire was flat and the plane looked like it was outside for days. I asked how long its been flat and outside and just shoulder shrugs. So..now the plan was to change out the tube for another new one except they did not even have anything of quality. but I was told that the one they would put on should be as good as any....they just wanted me out the door being it was near closing time. So I got a POS tube, my plane was filthy and I was on my way. Two months later now go to the hangar and see my nose tire low...22lbs. I cant even get the valve cover off without prying the stem away from the wheel with a tool. Even after inflated its a bitch. I had a nice metal valve cover on there originally but I just realized they replaced it with a cheap plastic one when they could not fit the metal one. I have an open checkbook mx policy on this plane and I still have issues. WTF is wrong with mechanics these days. You should not need to pry a valve stem off of a wheel to get the cap off. How can you let it leave a shop like that after an annual. To take it back would take an entire day out of my life. Its not around the corner. UPDATE: MX shop just called me and said my email was threatening and not to bring the plane back. Here is the email in its entirety : <<<<<<You just did my annual and we had that issue with my new nose tire and tube being deflated when I picked it up. I knew it would be an issue even when you fixed it and said it would be fine. So just two months after my annual my tire was flat this morning. Went to put air in it and found that the valve stem is so tight against the wheel. Also my metal cap has been replaced by a cheap plastic one. I see this was done because of the spacing. So now what do I do? I had a air stop tube on there that never gave me an issue. You threw it away and gave me a substandard replacement. It will take a whole day off for me to fly to Avon park.Just upset. I have an open checkbook mx policy on this plane and with that I still have issues.>>>>>>
Andy95W Posted May 2, 2021 Report Posted May 2, 2021 Jim, it sounds like you should be doing more of your own maintenance. Replacing tires/tubes is preventive maintenance that an owner can legally accomplish on his own, to include logbook entry. That way, you would’ve been sure to get the tube you wanted. ISTM a lot of your other issues could also have been avoided by doing more of your own work under the supervision of an A&P. You keep complaining about mechanics, but it looks like you’re not doing anything different to prevent these problems. 1 2
Jim Peace Posted May 2, 2021 Report Posted May 2, 2021 17 minutes ago, Andy95W said: You keep complaining about mechanics, but it looks like you’re not doing anything different to prevent these problems. 100% correct....but I am only home a limited amount of time and want to use that time to fly....not get greased up. Me writing checks as large as it takes should be enough. But its not. So I am not sure what to do at this point. An owner should be able to communicate what he wants and the mechanic/shop owner should be able to do the job correctly in exchange for money. I make sure my checks clear,,,,if we could just get the mechanics to do the job correctly life would be good. I know very little about A/C mx procedures. But I know throttles should not disconnect on the first flight and new tires and tubes should not be flat when picking them up on day 1 from the shop and I have a pretty good idea that carb heat is a required item on a carb equipped airplane not to be dismantled. Is there really something wrong with me? Or is it that mx shops are running a bit loose with a lack of FAA oversight.. I pay my bills the minute received. That should be enough. 1
RLCarter Posted May 2, 2021 Report Posted May 2, 2021 I’m not sure if the 70° stems are available for the 5” tires on the nose. The nose wheel isn’t near the pain the mains were, or at least not for me.
carusoam Posted May 2, 2021 Report Posted May 2, 2021 Sounds like it’s time to get to know two mechanics... really well. and visit both often... select one that is older with tons of experience... Select the other who wants to have tons of experience... Mooney ownership can be decades long... the old guy might retire... Best regards, -a- 2
A64Pilot Posted May 4, 2021 Report Posted May 4, 2021 (edited) You need to find a better shop, about the only way is by word of mouth. ‘Not everyone has the knack for turning wrenches, you just have different skill sets is all, I don’t expect my CPA to know how to time magnetos, and he knows I have no desire to learn about taxes. ‘If you can’t trust then to change a tire, can you trust them to work on your landing gear? Edited May 4, 2021 by A64Pilot 1
outermarker Posted April 29, 2025 Report Posted April 29, 2025 So, what tire and tube resolved this issue? Was a tube with an angle used, and does that tube hold air throughout the year? I'm asking because it is time for me to change my tires and tubes. I, too, have straight stems and live in fear of ruining the inner tube by pulling the stem away to check and apply air. Goodyear FS III has been on it since I bought it, and I'll assume the inner tube is also a Goodyear. The FS III is the only tire using Kevlar and has a speed rating of 160mph. Currently, a Goodyear FS III and tube are over $500; therefore, spending around $1500 for three tires and tubes and then the labor costs is a bit steep for the shallow pockets I wear. I have a lightweight, short-bodied E. A perfect scenario for me would have these elements. Inner tube: 1. the tube holds air throughout the year without leaking. 2. the valve stem with the metal cap on doesn't rub, lie against, or interfere with anything. Tire: 1. easy to balance or balancing is not required 2. good tread depth 3. resistant to dry rot or cracking after a few years Is there a tire and tube that meets all of the above? Surely there have to be people out there who are overjoyed with their tires and tubes AND happy with the price paid for the tires and tubes. I would really like to hear from you. thanks!
Andy95W Posted April 29, 2025 Report Posted April 29, 2025 We just talked about this a little bit ago. You’ll see links for the inner tubes with 70° stems that are made of the same rubber as the Michelin Airstop tubes. Also, you can send a message to Jim Peace and ask him what he bought.
Matthew P Posted April 29, 2025 Report Posted April 29, 2025 to degree for nose, 90 degree for mains...getting to the point you can't even rely on the MSCs to do a good job anymore.
Mkruger2021 Posted April 30, 2025 Report Posted April 30, 2025 HI Everyone, I need a tube for the nose. Ive tried both the goodyear and the aeroclasic. The stems are way too long to fit the dust cover. Does anyone have a part number for the short 90 degree or 70 degree that will allow the dust cover to go on the wheel? this is turning into a real PITA....
Jim Peace Posted April 30, 2025 Report Posted April 30, 2025 7 hours ago, Mkruger2021 said: HI Everyone, I need a tube for the nose. Ive tried both the goodyear and the aeroclasic. The stems are way too long to fit the dust cover. Does anyone have a part number for the short 90 degree or 70 degree that will allow the dust cover to go on the wheel? this is turning into a real PITA.... I did flight custom 3 all around with the M airstop tube for the nose and a different brand tube for the mains. The guys I used for the install let's just say were average, I am being kind. The valve stem touches the side of the wheel where my last one did not....I will have to use a screwdriver to get a pressure fitting on...My mains with the 70 degree stems are great. enclosed is a picture of my nose. Pictures of the rest are in that other thread I think. Also be sure that if you have hubcaps on your mains that your mechanic puts on and tightens all three screws. Otherwise you will have to hope the shop steps up and does the right thing,,,these guys at least did that... 1
Mkruger2021 Posted May 3, 2025 Report Posted May 3, 2025 So Michelin Airstop Tube....Thank You....Ditto to the rest....I'm aware of the bolts and the stem issue.....
Hank Posted May 4, 2025 Report Posted May 4, 2025 Airstops are great! I usually adjust air pressure in my tires now two or three times a year.
outermarker Posted May 4, 2025 Report Posted May 4, 2025 Today I attempted to install a new LEAKGUARD tube with 70 degree stem on the main rim. The new tube has about a 1/4” of rubber at the stem base that has to seat through the stem hole on the rim. I could not get the rim mounted onto the tire and the valve completely through and seated into the stem hole. I gave up completely defeated. What’s the secret?
Jim Peace Posted May 4, 2025 Report Posted May 4, 2025 6 hours ago, outermarker said: Today I attempted to install a new LEAKGUARD tube with 70 degree stem on the main rim. The new tube has about a 1/4” of rubber at the stem base that has to seat through the stem hole on the rim. I could not get the rim mounted onto the tire and the valve completely through and seated into the stem hole. I gave up completely defeated. What’s the secret? pictures of everything including wheels please
outermarker Posted May 11, 2025 Report Posted May 11, 2025 I don’t get an opportunity to give back and I’m so grateful to everyone who gives me help. This is an opportunity to perhaps help others. For those changing their tires and tubes I’ve enclosed a photo of the 70 degrees valve stem installed on the main tire. I used a Harbor Freight mini tire changer($56) to break the tire bead. Some hiccups I encountered. I wanted to use new bolts, washers and nuts on the rim halves. What I had was too long so additional washers were used. The bolt p/n in the Mooney parts manual was 1/8 too short. Also, the nut is a high temperature nut. Aircraft Spruce only has Nylock for that size. Nylock can be used on the nose wheel. What I learned was that I should have checked the Cleveland Parts Manual for the bolt length. So much for a DIY project! 1
Matthew P Posted May 12, 2025 Report Posted May 12, 2025 70 degree on mains and 90 degree on nose works perfectly 1
Jim Peace Posted May 13, 2025 Report Posted May 13, 2025 15 hours ago, Matthew P said: 70 degree on mains and 90 degree on nose works perfectly depends on the installer....so I found out.....having a A&P and a business that works on planes does not mean anything.....
skipswift Posted August 26, 2025 Report Posted August 26, 2025 Hi. I bought an AERO CLASSIC 500-5 GL-5087B short 90 degree tube for my nose gear wheel and unfortunately the stem is angled such that it presses against the wheel hub making it nearly impossible to attach an inflator. Will the 5067B with the longer 90 degree stem solve this problem or do you recommend a different tube? Would love makes/model #s and/or links. Thanks in advance.
Bob E Posted August 27, 2025 Report Posted August 27, 2025 I've owned my '65 M20C for almost 40 years. Straight-stem tubes resulted in numerous flat tires, often on landing. About 20 years ago I switched to 90 degree bent stem tubes on both nose and main gears and have had zero problems since. Specs that work for me: Nose gear tube: Aero Classic Leak-Guard Tube 500 x 5 90 deg stem, part # 06-00755: https://www.aircraftspruce.com/catalog/lgpages/leakguard_06-00755.php Main gear tubes: Aero Classic Tube 600-6.5, part # GL-6067N: https://www.aircraftspruce.com/catalog/lgpages/aero_tube_600_6_67a.php If you want to change the tires and tubes yourself, I recommend Harbor Freight's mini tire changer: https://www.harborfreight.com/mini-tire-changer-58920.html. Very easy to use. You'll need tire talc. Don't use baby powder; it's now corn starch and has no talcum powder. Amazon has the correct stuff: https://www.amazon.com/mGanna-Natural-Make-up-Cosmetic-formulations/dp/B0BM4PKJ8K/ BTW most people recommend getting new tubes with each tire change. I agree, but frankly the old tubes fit so well they are perfectly serviceable, so I save them and keep one of each (nose and main) in the baggage area as spares. They weigh almost nothing. If I have to replace a tube, I'll take a used bent-stem over a new straight-stem any day.
skipswift Posted August 29, 2025 Report Posted August 29, 2025 On 8/26/2025 at 11:55 PM, Bob E said: I've owned my '65 M20C for almost 40 years. Straight-stem tubes resulted in numerous flat tires, often on landing. About 20 years ago I switched to 90 degree bent stem tubes on both nose and main gears and have had zero problems since. Specs that work for me: Nose gear tube: Aero Classic Leak-Guard Tube 500 x 5 90 deg stem, part # 06-00755: https://www.aircraftspruce.com/catalog/lgpages/leakguard_06-00755.php Main gear tubes: Aero Classic Tube 600-6.5, part # GL-6067N: https://www.aircraftspruce.com/catalog/lgpages/aero_tube_600_6_67a.php If you want to change the tires and tubes yourself, I recommend Harbor Freight's mini tire changer: https://www.harborfreight.com/mini-tire-changer-58920.html. Very easy to use. You'll need tire talc. Don't use baby powder; it's now corn starch and has no talcum powder. Amazon has the correct stuff: https://www.amazon.com/mGanna-Natural-Make-up-Cosmetic-formulations/dp/B0BM4PKJ8K/ BTW most people recommend getting new tubes with each tire change. I agree, but frankly the old tubes fit so well they are perfectly serviceable, so I save them and keep one of each (nose and main) in the baggage area as spares. They weigh almost nothing. If I have to replace a tube, I'll take a used bent-stem over a new straight-stem any day. Thank you for the quick response and the detail! Going to order the Aero Classic GL-5067B and keep my fingers crossed the valve doesn't press against the wheel hub so tightly I can't easily attach an inflator.
Bob E Posted August 29, 2025 Report Posted August 29, 2025 4 hours ago, skipswift said: keep my fingers crossed the valve doesn't press against the wheel hub If it does, it's installed incorrectly. One advantage of DIY is that you can position the valve precisely as it should be, which is NOT pressing against the hub.
Jim Peace Posted September 5, 2025 Report Posted September 5, 2025 On 8/29/2025 at 7:34 PM, Bob E said: One advantage of DIY is that you can position the valve precisely as it should be, which is NOT pressing against the hub. not sure why mechanics don't do this.... Do they think we don't notice?
