N9405V Posted April 1, 2021 Report Posted April 1, 2021 Who would you recommend? I’m located in Texas but would travel. At a minimum I’m looking to install a GFC500 and whatever needs to drive it. I’ve got a GTN650 so that’s a start. Thanks! Sent from my iPhone using Tapatalk 1 Quote
PMcClure Posted April 1, 2021 Report Posted April 1, 2021 Hey - take a look at my post. PM if you want any info. Mine was an Ovation, but it may get you started. One thing to note - the internal g3x nav is not suitable for any serious navigation. So, you need 2 nav sources for any serious IFR. 2 Quote
gsxrpilot Posted April 1, 2021 Report Posted April 1, 2021 https://advancedaerotech.com These guys in Greeley, CO have done the GFC500 on a few Mooneys and seem to have the best rates. I'm hearing $17,000 out the door for the GFC500 and the G5 to drive it. @Warren and @PJClark are a couple of references. I know of a couple of others as well. If you came to Colorado, I might be able to help with transportation. 2 Quote
icurnmedic Posted April 1, 2021 Report Posted April 1, 2021 2 hours ago, gsxrpilot said: https://advancedaerotech.com These guys in Greeley, CO have done the GFC500 on a few Mooneys and seem to have the best rates. I'm hearing $17,000 out the door for the GFC500 and the G5 to drive it. @Warren and @PJClark are a couple of references. I know of a couple of others as well. If you came to Colorado, I might be able to help with transportation. Wow. $17k ? If this is the case sounds like a heck of a deal. I am quoted and scheduled my GFC500 install at $19500. Quote
gsxrpilot Posted April 1, 2021 Report Posted April 1, 2021 11 minutes ago, icurnmedic said: Wow. $17k ? If this is the case sounds like a heck of a deal. I am quoted and scheduled my GFC500 install at $19500. I try to follow what people are spending around the country for this. This is the cheapest I've seen for actual installs done. Quote
carusoam Posted April 1, 2021 Report Posted April 1, 2021 Inviting @Rmag to the conversation... He just posted a pic of his latest panel update... Best regards, -a- Quote
Rmag Posted April 1, 2021 Report Posted April 1, 2021 Hi! We could surely do it, but PA is a looooong way from TX. You want to find a good shop close to home base that will give you good support too. 2 Quote
ArtVandelay Posted April 1, 2021 Report Posted April 1, 2021 I try to follow what people are spending around the country for this. This is the cheapest I've seen for actual installs done.Be careful with quotes, they can be 2,3,4 servos....sometimes with G5, sometimes not, sometimes tax is extra, etc. 2 Quote
N9405V Posted April 2, 2021 Author Report Posted April 2, 2021 Hi! We could surely do it, but PA is a looooong way from TX. You want to find a good shop close to home base that will give you good support too.Definitely a long way away, but it’s a Mooney. What’s the best way to get in touch with you to talk?Sent from my iPhone using Tapatalk Quote
Shiny moose Posted April 2, 2021 Report Posted April 2, 2021 I am also looking for a GFC500 install in the midwest, since Jan i was on a waiting list, then for the last 3 weeks my plane sat at a what was at one time a respectable avionics shop, they never ordered anything, just gave me a lot of lip service. Lots of lies and confusing statements, from the bosses daughter. Picked up the plane yesterday. Quote
Rmag Posted April 2, 2021 Report Posted April 2, 2021 18 hours ago, ArtVandelay said: Be careful with quotes, they can be 2,3,4 servos....sometimes with G5, sometimes not, sometimes tax is extra, etc. This is true. I can honestly state that we can install a GFC500 and a G5 in the low $16k range. Of course, if you want it interfaced to a GPS, you want a temp probe for TAS, oh... you want a pitch trim servo? Add several thousand more. PA is no tax on aircraft work fortunately. 2 Quote
Rmag Posted April 2, 2021 Report Posted April 2, 2021 2 hours ago, N9405V said: Definitely a long way away, but it’s a Mooney. What’s the best way to get in touch with you to talk? Sent from my iPhone using Tapatalk We are closed tomorrow for Good Friday, you can call me at the office M-F 484-718-3136, ask for Dan tell them you’re the Texan calling from Mooneyspace you can also shoot me a PM here if you have specific questions. I own the company, and I am a pilot, so I use the equipment, but I have managers that build the quotes and handle the really technical questions! 1 Quote
Ragsf15e Posted April 2, 2021 Report Posted April 2, 2021 Here’s a stupid question about the GFC500 installs on vintage airplanes... if you get the pitch trim servo and/or yaw damper, must you also wire an electric pitch and/or yaw trim switch? Or can you just manually turn the pitch trim when you’re hand flying? I wouldn’t want the expense or trouble of trying to wire electric trim for my hand flying, but the pitch trim is very nice when George is flying. Quote
carusoam Posted April 2, 2021 Report Posted April 2, 2021 Early 90s BK systems have... 1) Pitch servo 2) Roll servo 3) pitch trim servo 4) Rudder trim Servo. 5) not able to limit any tail wag... PP thoughts only, -a- Quote
donkaye, MCFI Posted April 2, 2021 Report Posted April 2, 2021 44 minutes ago, Rmag said: This is true. I can honestly state that we can install a GFC500 and a G5 in the low $16k range. Of course, if you want it interfaced to a GPS, you want a temp probe for TAS, oh... you want a pitch trim servo? Add several thousand more. PA is no tax on aircraft work fortunately. I don't see how you can make any money. From several bids I got before I installed my GFC 500, the parts alone for a 4 servo system including adding the G5 came to $16,000. Quote
donkaye, MCFI Posted April 2, 2021 Report Posted April 2, 2021 13 minutes ago, Ragsf15e said: Here’s a stupid question about the GFC500 installs on vintage airplanes... if you get the pitch trim servo and/or yaw damper, must you also wire an electric pitch and/or yaw trim switch? Or can you just manually turn the pitch trim when you’re hand flying? I wouldn’t want the expense or trouble of trying to wire electric trim for my hand flying, but the pitch trim is very nice when George is flying. A trim switch (also used for manual trimming when the AP is not engaged) is added on the yoke and the Y/D is engaged on the GMC 507 Mode Controller and disengaged on GMC 507 or AP disengaged switch on the yoke.. Quote
gsxrpilot Posted April 2, 2021 Report Posted April 2, 2021 19 hours ago, ArtVandelay said: Be careful with quotes, they can be 2,3,4 servos....sometimes with G5, sometimes not, sometimes tax is extra, etc. You are quite correct. The $17,000 I've seen here in Colorado is not a quote but what was actually paid. It was a 3 servo (no yaw damper) with G5, and interfaced to a GNS430W. I've seen it flying as well and it's really nice. Quote
Rmag Posted April 2, 2021 Report Posted April 2, 2021 27 minutes ago, donkaye said: I don't see how you can make any money. From several bids I got before I installed my GFC 500, the parts alone for a 4 servo system including adding the G5 came to $16,000. I couldn’t make money on a 4 servo system at that price. I was just saying a basic GFC500 (2 servos and a G5 only) could be done at that pricing. It’s not realistic though as most people get the pitch trim servo and the GPS interface. Quote
ArtVandelay Posted April 2, 2021 Report Posted April 2, 2021 Here’s a shop advertisement with breakdown of pricing: https://avionics-laf.com/products/garmin-gfc500-autopilot-installed Notice Mooneys are an extra $1500, but Pipers are $3000 extra.A 3 servo with 1 G5 runs around $20.5 AMUs. Quote
vorlon1 Posted April 2, 2021 Report Posted April 2, 2021 6 hours ago, donkaye said: A trim switch (also used for manual trimming when the AP is not engaged) is added on the yoke... Yeah, that's a problem. There is no (obvious/easy) way to add it. I have the original yokes. 1 Quote
ArtVandelay Posted April 2, 2021 Report Posted April 2, 2021 Yeah, that's a problem. There is no (obvious/easy) way to add it. I have the original yokes. <_> There’s no problem in aviation that money can’t fix. 1 1 Quote
Ragsf15e Posted April 2, 2021 Report Posted April 2, 2021 8 hours ago, vorlon1 said: Yeah, that's a problem. There is no (obvious/easy) way to add it. I have the original yokes. Exactly. Quote
PJClark Posted April 2, 2021 Report Posted April 2, 2021 My actual cost at AATG, parts, installed, flown away complete: G3X touch 10.6" $13,500 GFC500 2 axis $10,742 Pitch trim installed: $3011 G5 backup installed: $3253 Total $30,496 Reading it right off the quote and I paid not a dime more. Not shown above was a GTN750, GTX345R, EDM900 Primary, all installed at the same time. Paid exactly the quoted price for all. 9 Quote
dominikos Posted April 3, 2021 Report Posted April 3, 2021 3 hours ago, PJClark said: My actual cost at AATG, parts, installed, flown away complete: G3X touch 10.6" $13,500 GFC500 2 axis $10,742 Pitch trim installed: $3011 G5 backup installed: $3253 Total $30,496 Reading it right off the quote and I paid not a dime more. Not shown above was a GTN750, GTX345R, EDM900 Primary, all installed at the same time. Paid exactly the quoted price for all. Paul, what did you pay for a new panel? I’m being quoted $6K here in TX. Don’t know if that’s reasonable or not. Quote
PJClark Posted April 3, 2021 Report Posted April 3, 2021 NOT. My panel was $2810 including the blank on copilot side, my choice of powdercoat color and texture 1 Quote
