Im going to hell. It took 237 curse words to get the wire into the small hole in the stud. The oil heat exchanger mocks me the whole time while the cable housing punctures my finger tip releasing bright red corrosive fluid. There’s got to be a better way, so share your secrets.
20 hours ago, N201MKTurbo said:
Take the screws out of the oil cooler along with the hose clamps on the heat shield and push the oil cooler aside. You can access it through the oil cooler hole.
Do this...... you will be much happier.... :D
Thanks for all the replies. I realized after some checking that there were various different designs For the cable attach point so only those with my style probably feel my pain.
Anthony, it was finished and closed up by the time I posted this and I was at the height of my frustration so no pictures and I didn’t want to dig back into it. I did find a pic on Mooneyspace from another poster that I attached here that resembles mine.
MKturbo, Moose, Chump, Mitch and Yetti. I did have the oil, cooler unbolted but it only provided minimal room to negotiate with my hand. In the end I was able to get it attached and my mechanic was satisfied with the result.
Nuke, send your most useful curse words so I can be prepared for the next lower cowl removal.
Gary, now I really like your idea. I will be looking into the oil cooler relocation STC. Seems like it would be  Yuge plus.
Steve
photo credit @apenney
Steve
After my last annual, on the test flight, I pulled that knob in the cockpit and it came completely out in my hand.  After i landed with it open and taxiied to my mechanic I heard some pretty good words.  It had been attached but not tightened enough.  Hope yours stays attached!
