Skates97 Posted September 20, 2020 Report Posted September 20, 2020 JPI EDM830 for sale. Installed 11/15/2017, it has 246 hours on it. Removed for a 900 installation. EGT, Carb Temp, 3 CHT sensors (not the ring one for the #1 cylinder), RPM sensor, fuel flow transducer, OAT sensor, P1 and P2 harnesses are all new. Oil temp, oil pressure, MAP sensors are used.
Matt Ward Posted September 21, 2020 Report Posted September 21, 2020 Assuming this was in a C model, what would it take to make it work in an IO360 E model? Would it have to go back to JPI?
Alan Fox Posted September 21, 2020 Report Posted September 21, 2020 No , The parameters are user programmable...
carusoam Posted September 21, 2020 Report Posted September 21, 2020 It would need installation... 1) The fuelP sensor for the O360 May be a different range than the IO360... But I don’t see FuelP on the list... FF is the more important piece of info... if you have FF, you have FuelP as well... PP thoughts only, not a mechanic... Best regards, -a- 1
bradp Posted September 21, 2020 Report Posted September 21, 2020 Fuel P was never an option on the 830 series unfortunately
