JBear Posted March 14, 2020 Report Posted March 14, 2020 (edited) I just recently completed the refurbish of my Mooney's interior, including patching cracked plastic panels, re-painting, redo the edge trim and installed with all new sheet metal screws. I also replaced the carpet and replaced the seat cover from fabric to Vinyl leather, as well as replace some side windows. It took me about 3 months ( less than 10 weekends) including took them off, planning, waiting on goods, patching and painting plastics and installation.Bruce Jaeger from jaegeraviation.com helped me greatly. Without his help and some of his unique products, I don't think I would be able to successfully accomplished all by myself. He answered all my questions from numerous emails tirelessly (even if you don't order his product). So feel free to give him a call and emails.I used some of his unique products that I was not able to find anywhere else (and reasonable priced):(1) silicon edge trim and adhesive -- very beautiful and replace my old, stiff edge trims.(2) color match painted sheet metal screws -- I use them around the windows.(3) Mooney ceiling vent louver rebuild kits -- without that, my project will be a total failure since I broken them when I removed the headliner and no one else sells any replacement parts.(4) Thick 3M alumina tapes and plastic panel patch pieces -- I used them to repair cracks and reinforce the weak area of the plastic panels.(5) His repair instruction tips PDF (free)He has other stuffs beside what I've used. Please see his web page and talk to him.Here is some of my essential repair and painting steps and products that I use.Clean up plastics: Remove side padding for upholstery wrap leather. (Mooney has side paddings glue on top of plastic panels) Scrapping the old glue. Clean up the remaining glue and dust using 3M 38983 and the following. Use the following 2 from Aircraft Spruce Qty Ship B/O Item Unit Price Total Price 1 0 1 09-03575 SEM VINYL PREP 16 OZ AEROSOL 17.850 17.85 1 0 1 09-03588 SEM AEROSPACE SOAP 15 OZ 16.500 16.50Repair Plastic Panels: Repair with 3M thick alumina tape (and plastic plates if needed, all purchased from Bruce), reinforce the back of weak area by applying 3M EzSand or USC Flexible Glaze, surface fixed with smearing USC Flexible Glaze, then light sanding after dry. Note that 3M EzSand is a flexible epoxy for bumper repairing (also recommended by Bruce). But I found the USC Garage Flexible Glaze is a better product because it's color is almost white (instead of EzSand dark-grey), and it is much cheaper and much easier to mix. This is the latest epoxy technology for plastic bumper repairs. I believe Bruce now will recommend this one instead of 3M EzSand after read my feedback to him and trial himself.USC Garage bumper repair instruction video Parts: USC Garage Flexible Glaze can be purchased from many online auto-paint stores. About $15 a bag. You won't need more than 2 bags. 3M EzSand price is vary greatly. I purchased 650ml from eBay for only $30 (normally over $100) Epoxy mixing board - I found the following mixing broad the best one. Clean Sheets Superior Mixing Pad (12x12) - 100 Disposable Sheets For Toughest Job Sold by: MetaRetail (Amazon) Epoxy Mixing stick: Local Ace Hardware (plastic sticks in a bag 20 for $3. Flexible Epoxy blazes: you may or may not need them. You can get them from Amazon. Silicon or Vinyl gloves from Harborfrieght Sand papers of 100, 250. Both regular and for the electric sanders.Painting: Clean the surface before paint Bulldog adhesion promoter -- base primer (see instruction on the cane... I start spray the SEM paint 7 minutes after apply promoter) Apply SEM 39853 (video) (texture or Dupli-Color TSP100 Grey and White Trunk Paint.. https://www.ss396.com/ x2 ) This is for adding texture needed after surface repair because after sanding, the surface of the repaired area is smooth. I have to redo the texture of the entire area. I used Dupli-Color TSP100 (recommended by Bruce) because SEM39853 is black color. According to Bruce, SEM39853 will be very hard to cover it up. Dry and sand (pattern table in video) - (skipped sanding in my case) Apply SEM Super White 15103 (JB Tools x 6 ). Note that Super White is not really white-white but vanilla color (similar to what the original color of my panel) Protective coat - Dupli-Color HWP106 Wheel Matte Clearcoat. -- for UV protection. It can be optional. Silicon or Vinyl gloves, from Harborfrieght Bench Brush from Harborfreight for cleaning (also used pressure air) P95 Maintenance-Free Dual Cartridge Respirator from Harborfreight. Mask tapes and work paper roll from HomeDepotOld Panel Installation Tips:Get the 2 thinnest drill bits, such as the #6 screws' guide drill bit 7/64 or less. Hold the panel on to the fuselage while use the thinnest drill bit to poke into the existing screw hole on the plastic and find the underlying hole on the fuselage. Once found it, keep the drill bit there and use another drill bit do the same thing on the other side of panel until both are aligned. Now you have easy time to put all the screws into each hole using a electric screwdriver. BE VERY CAREFUL, NOT tight it up too much or it can crack the plastic. I use the electric driver to tight each screw to 90%, then tight it by hand using regular screwdriver. Screws, donut washers for plastic purchased from Aircraftspruce. I later on found them also at Ace hardware, much cheaper. Painted screws from Jaeger Aviation (Bruce). Those are specially made and imported from Taiwan.CarpetRemove old carpet and need plastic scrapping the remaining glue using Scraper with plastic blades (Amazon), and 3M 38983 adhesive remover. When put on the new carpet, I use 3M High Strength 90 Spray Adhesive (from HomeDepot) to glue the carpet Carpet: I got it from https://www.airtexinteriors.com/catalogue/carpets.php Airtex Interios Plastic scraper: I got it from Amazon. -- 2 Pack Razor Blade Scrapers + 100 Pack Plastic Replacement Blades Stickers Decals Paint Labels Scraper Removal Tool for Auto Window Glass Tint Vinyl Tool NO ScratchedSide WindowI ordered from http://www.glapinc.com Note that windshield can only be installed by a A&P. SeatReplace with Vinyl leather using local automobile upholstery shop. The certified material can be purchased from a online shop or, if you elect to use the materials from a local shop, You can get an instructions from Bruce of how to send to a burn test agency in order to pass FAA requirements. Note that I add a side pocket on each of the front seat on the side of between 2 seats (on the seat back). This allow me to put in the oxygen bottle and other stuff I need. It is a very useful improvement when doing seats. The above is a simplified version of my refurbish log. I hope this helps. Edited March 15, 2020 by JBear 3 3
Guest Posted March 15, 2020 Report Posted March 15, 2020 Have you got any pictures of your makeover? Clarence
JBear Posted March 15, 2020 Author Report Posted March 15, 2020 (edited) 4 hours ago, M20Doc said: Have you got any pictures of your makeover? Clarence Unfortunately, I did not take any before-and-after pictures. I realized I did not take pictures after I already teared down the interior. So I did not bother to take the "after" when it was done. But you can imagine most of my panels near the windows were crumble and cracked, discolored and looked really old. The screws were all oxidised. The seat fabric were discolored on some area. headliners also cracked in some corner. The carpet shrink and exposed the metal floor at the rare end. Now it looks new, great carpet and shining screws. Milky windows now becomes extremely clear. The air louvers converted from 5 inch plates to modern nipple style outlet and worked really well. Edited March 15, 2020 by JBear
ArtVandelay Posted March 15, 2020 Report Posted March 15, 2020 Mooney ceiling vent louver rebuild kits? What are these, where did you get them, how difficult was it?
RLCarter Posted March 15, 2020 Report Posted March 15, 2020 19 minutes ago, ArtVandelay said: Mooney ceiling vent louver rebuild kits? What are these, where did you get them, how difficult was it? http://jaegeraviation.com/
carusoam Posted March 20, 2020 Report Posted March 20, 2020 Nice pirep, Jbear! Thanks for sharing. Bruce has helped a few MSers update their interiors... with great results... Best regards, -a-
