Tim Jodice Posted February 18, 2020 Report Posted February 18, 2020 I replaced the baffles in my J with a kit from Guy and they fit beautifully! Hoses and baffles Guy is your man! 3
carusoam Posted February 18, 2020 Report Posted February 18, 2020 Great pirep with awesome pics, Tim! Thanks for sharing the details. Best regards, -a-
Yetti Posted February 20, 2020 Report Posted February 20, 2020 You are out of oil on your engine. There is none leaking out. 1
OR75 Posted February 26, 2020 Report Posted February 26, 2020 how much does the baffling for a J cost ?
MrRodgers Posted February 26, 2020 Report Posted February 26, 2020 HMMM... I'd double check the parts from Gee Bee Aero Products to make certain they were approved and safe. Just found this on the FAA Website. FAA PROPOSED FINE - Unapproved Parts $203,100 July 2019
carusoam Posted February 26, 2020 Report Posted February 26, 2020 4 hours ago, MrRodgers said: HMMM... I'd double check the parts from Gee Bee Aero Products to make certain they were approved and safe. Just found this on the FAA Website. FAA PROPOSED FINE - Unapproved Parts $203,100 July 2019 Oldish news... with follow-up to the story... Corrections in place... And documented around here someplace... Good catch though! Best regards, -a-
MrRodgers Posted February 26, 2020 Report Posted February 26, 2020 Oldish news... with follow-up to the story... Corrections in place... And documented around here someplace... Good catch though! Best regards, -a- Okay. ThanksSent from my iPhone using Tapatalk 1
PT20J Posted February 27, 2020 Report Posted February 27, 2020 On 2/25/2020 at 4:17 PM, OR75 said: how much does the baffling for a J cost ? Mine were $225 + shipping in late 2018. Kit includes die cut baffle seals, pop rivets and barrel screws -- everything you need. The original seals are attached with hardened staples. You need a Dremel with a cutoff wheel to remove them. Guy supplied a couple of cutoff wheels also. His SCEET tubing is double wall and much better than SCAT. With the finished ends, they should last at least to TBO. Skip 2 1
OR75 Posted February 27, 2020 Report Posted February 27, 2020 link to a website to look at products / prices ?
Tim Jodice Posted February 27, 2020 Author Report Posted February 27, 2020 On 2/20/2020 at 1:03 PM, Yetti said: You are out of oil on your engine. There is none leaking out. Not yet. At 200 hours SMOH I hope not!
carusoam Posted February 27, 2020 Report Posted February 27, 2020 Searching around here may get you the various Mooney parts for @GEE-BEE... other contact details can be found here... https://www.csobeech.com/GeeBee.html PP thoughts only, not a recommendation because I’m not a mechanic... Best regards, -a-
Vlakvark Posted March 6, 2020 Report Posted March 6, 2020 On 2/25/2020 at 10:35 AM, GEE-BEE said: Nice tight installed done correct ams3320 cut to your spec's Ducts per your dimensions I.D X LENGTH Where can I buy these?
carusoam Posted March 6, 2020 Report Posted March 6, 2020 On 2/27/2020 at 1:07 PM, carusoam said: Searching around here may get you the various Mooney parts for @GEE-BEE... other contact details can be found here... https://www.csobeech.com/GeeBee.html PP thoughts only, not a recommendation because I’m not a mechanic... Best regards, -a- 2 minutes ago, Vlakvark said: Where can I buy these? Vlak, Note the link above... CSO.... That May be the way to place an order...? Best regards, -a-
carusoam Posted March 19, 2020 Report Posted March 19, 2020 On 3/18/2020 at 1:40 AM, GEE-BEE said: N77gb@msn.com 800 556 3160 ducts made to your spec GB Memory strategy to find Guy later on... When looking for Guy the seal guy... now I only have to put seal guy in the search box... Best regards, -a-
carusoam Posted March 25, 2020 Report Posted March 25, 2020 Nice pics... And Jim Kerr’s pirep is nice too... “Guy at Gee Bee is a super nice fellow, but they don't have a website. You have to call him or email. They can be reached at 800-556-3160or via email at n77gb@msn.com. Guy isn't always around to answer the phone, but he is generally very responsive if you leave him a voicemail or send an email.” - JK Best regards, -a- 1
Costa Leite Posted April 6, 2020 Report Posted April 6, 2020 On 2/27/2020 at 3:11 AM, PT20J said: Mine were $225 + shipping in late 2018. Kit includes die cut baffle seals, pop rivets and barrel screws -- everything you need. The original seals are attached with hardened staples. You need a Dremel with a cutoff wheel to remove them. Guy supplied a couple of cutoff wheels also. Last year we also had new Seals on our 1998 M20J Allegro ordered from GeeBee. Price was 275usd + 90usd for ship to Europe. Colour in Royal Blue and Silver pop rivets. Guy also offered a free set of valve cover gaskets. Our feedback is 100% positive. This is a great product with perfect fit on cowl. Be aware to follow GB recommendations on installation, like the slight rear seal forward bend. The Engine temps just got right low after seals installation. Check the pictures below to see the quality product and to understand also the difference between the original hardened staples and the new rivets for seals attachment that PT20J commented. 3
carusoam Posted April 7, 2020 Report Posted April 7, 2020 Great detailed pics Costa! Thanks for sharing them... Best regards, -a-
