spectre6573 Posted January 15, 2020 Report Posted January 15, 2020 Gents, I might be missing this somewhere but is a cabin speaker required? Thanks
RLCarter Posted January 15, 2020 Report Posted January 15, 2020 (edited) My IA had me replace mine (was noted in the pre-buy as being missing) Edited January 16, 2020 by RLCarter
0TreeLemur Posted January 15, 2020 Report Posted January 15, 2020 If a radio is required, you need some way to listen to it. If your intercom is working and you have a headset, you are covered. In my a/c the speaker is a convenience so I can listen to comms without headphones. That is pretty much only possible when not in flight. In flight it is hard to hear the speaker.
rbridges Posted January 16, 2020 Report Posted January 16, 2020 All those old pilots and flight instructors with hearing loss can vouch for its utility. 1
carusoam Posted January 16, 2020 Report Posted January 16, 2020 So.... Not required... But... When it comes to plans B... A second headset, plugged into a second set of receptacles... Can work... Or the speaker in the ceiling works... If you have any questions about hardware that is required... go to the POH... there is a list of required equipment in there... often it is a few lists to cover what is needed for VFR, IFR, Day, Night... PP thoughts only, not a CFI... Best regards, -a-
