ragedracer1977 Posted July 3, 2019 Author Report Posted July 3, 2019 @oregon87 or anyone else knowledgeable, I found a decent deal on an FP-5L. Can I just splice into the existing transducer wiring before the FM-FLOW module? Or do I eliminate the flow module entirely and take that function off the UBG16? Quote
oregon87 Posted July 3, 2019 Report Posted July 3, 2019 12 hours ago, ragedracer1977 said: @oregon87 or anyone else knowledgeable, I found a decent deal on an FP-5L. Can I just splice into the existing transducer wiring before the FM-FLOW module? Or do I eliminate the flow module entirely and take that function off the UBG16? You can absolutely splice into the existing transducer. Cap the red and black wires from the FP-5 as the transducer will receive the power and ground from the FM-FLOW and split the signal from the transducer's white wire to the FM-FLOW and FP-5. 1 Quote
