I’ve found one issue with my p leads recently that I’m pretty sure is contributing to some ignition noise I’m getting on my 430.  There is a bit of oil from an old spill during oil change that has invariably tracked up the p lead shielding.  Trying to figure out how I can use a solvent to clean it up, and reseal it from the environment without having to replace the entire run to the ignition switch.
