mike20papa Posted July 23, 2016 Report Posted July 23, 2016 (edited) ok Edited July 24, 2016 by mike20papa
RR ENGINEER Posted June 7, 2020 Report Posted June 7, 2020 (edited) Air intake duct M20E &F PART # 600115-005 I need one for my M20E IO 360A1A they are at least 350.00 to 400.00 new if you can find one Lasar Aircraft are out of stock . I am going to take mine off and spray that Flex Seal on it have put some on and it seems to be working just have to put layer after layer on let each layer dry before you add more. This part is very poorly construed . Looks like to me the flex seal will make it better. Going to put it on and run it just be sure to inspect after flying each time for a while. Edited June 7, 2020 by RR ENGINEER
MoonFlyer68 Posted June 7, 2020 Report Posted June 7, 2020 2 hours ago, RR ENGINEER said: Air intake duct M20E &F PART # 600115-005 I need one for my M20E IO 360A1A they are at least 350.00 to 400.00 new if you can find one Lasar Aircraft are out of stock . I am going to take mine off and spray that Flex Seal on it have put some on and it seems to be working just have to put layer after layer on let each layer dry before you add more. This part is very poorly construed . Looks like to me the flex seal will make it better. Going to put it on and run it just be sure to inspect after flying each time for a while. Alan Fox was selling some just a week ago in the forums. He may still have some.
flyingchump Posted June 29, 2020 Report Posted June 29, 2020 On 6/7/2020 at 9:33 AM, RR ENGINEER said: Air intake duct M20E &F PART # 600115-005 I need one for my M20E IO 360A1A they are at least 350.00 to 400.00 new if you can find one Lasar Aircraft are out of stock . I am going to take mine off and spray that Flex Seal on it have put some on and it seems to be working just have to put layer after layer on let each layer dry before you add more. This part is very poorly construed . Looks like to me the flex seal will make it better. Going to put it on and run it just be sure to inspect after flying each time for a while. Seriously, Flex seal? Did it work? hows it going? I too am now in need of replacement or repair.
