I have a bad right fuel gage, it barely moves and shows empty with full tank. Left gage seems to be ok. Both fuel gages are part of the Garwin 6 gage cluster, anyone have any ideas where I can get replacement fuel gages? I've heard of a place in PA.,, Air parts of Lockhaven. Was gonna contact them tomorrow.  Any advice would be appreciated
It may be the sender, not the gauge. You need to check them with ohmmeter, range should be approximately 1-30 ohms depending on float position.
Welcome aboard, Joe.
It always helps to know what plane you are flying, and what year it was born...
How interested are you in determining the details yourself?
The low cost method is determining what is working and what’s isn’t.
The high cost method is a complete digital replacement.
the level sensors in the short body Mooneys are hidden behind the side wall in the cabin.  They can be removed and cleaned, and have the seal replaced if this hasn’t been done in a while....
The Long bodies and some others have four sensors...
If the sensor is working, and the wire is not broken or disconnected the gauge in the panel is your next best chance of finding the failure.
Make no assumptions, everything wears over a few decades...  even the gauge grounds need to be checked.
If you know the gauge isn’t working The people in Lockhaven are known to do a good job...
If you are going all digital, now may be the best time to connect digital sensors to a digital engine monitor....
Also Check the things for sale, often the Garwin gauges are in there as people pull them for  JPI upgrades.
A brief search can find this stuff here on MS.
Best rgeards,
I have a garwin 6 pack for sale cannon plug type from a 64c with 52 gallons......just took it out for my jpi900 install
Thanks Jim, were all the cages working and what are you looking to get for it? I'm not far from you KMGJ
If you expose the fuel quantity transmitters which are behind the upholstery panels, remove the wires from them.  Then using jumper wires crisscross the wires and transmitters, this will tell you if it’s a gauge or transmitter.
Joe,
For an interesting read... there are a few MSers that have put digital fuel sensors to go with there digital engine monitors,  in their Mooneys...
These will bring your sensors up to new milinium standards.
We have a guy... search for @fuellevel or CIES....
As of 4/18/18, I have a Garwin 6-pack cluster for sale on eBay, with bad oil temperature gauge, item number: 123078534718   Presently valued at $5.50+shipping.
