The white needle on the wing mounted fuel gauge broke off on my '83 J and is moving around inside of the clear plastic cover.
Is there a supplier that still makes these or do I need to start searching salvage yards?
All you need is the wing site gauge. See Bob, the Parts Manager at Premier. He's a good guy and will treat you right IF you say hi from me. I think the gauge is under $100 and you can DIY or have Phil do it. Good luck.
You should be able to get them from your favorite Mooney Service Center fairly inexpensively--I'm pretty sure I've seen them for $35 or less.  Replacement is an easy (but not legal) DIY job--pop the old gauge out of its socket with an icepick, clean out the RTV sealant, apply new sealant, and put the new gauge in place.
The replies here have been pretty consistent. I was under the impression that this was going to cost me hundreds but I guess not everything related to maintenance is outrageous.
The fuel sender is the expensive part.
The connection between the sender and the indicator is a magnetic coupling.  The indicators get old, they are not really water tight and are susceptible to UV degradation.
My MSC replaced one this year after my annual for well under $100 including labor....
There's always room for some debate of course, but I would argue that it could fall into a few different categories, such as:
12. Making small simple repairs to fairings, nonstructural cover plates, cowlings, and small patches and reinforcements not changing the contour so as to interfere with proper air flow. (The fuel gauge is inside a non-structural cover plate.)
26. Replacement or adjustment of nonstructural standard fasteners incidental to operations. (Not really a fastener per se, but certainly incidental to operations.)
And my favorite...
29. Removing, checking, and replacing magnetic chip detectors. (I have no idea what this was originally intended for, but certainly the outside fuel gauge is EXACTLY a magnetic detector since it relies on a magnetic signal from the inside sender unit.)
The outside fuel indicators on a 231 I sawed the wings off of had the guages that the indicator was affixed to a spiraled rod. It looks to made by a lawn mower gas guage co. A magnetic chip sensor is normally used in helicopter tranmissions and tail gear boxes. Gives you a little heads up on your next BBBBBBIIIIIIIGGGGGG maint. bill.
larry
larry
