75_M20F Posted June 13, 2017 Report Share Posted June 13, 2017 Is the factory cowling on a 201/j model fiberglass? Thanks! Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted June 13, 2017 Report Share Posted June 13, 2017 Yes.Sent from my LG-US996 using Tapatalk Quote Link to comment Share on other sites More sharing options...
carusoam Posted June 13, 2017 Report Share Posted June 13, 2017 I believe so... The G was probably the last aluminum boxy shaped cowl. the J got a lot of swoopyness added to the cowl... Byron has shown the specifics of repairing the fiberglass in a thread around here. Best regards, -a- Quote Link to comment Share on other sites More sharing options...
75_M20F Posted June 13, 2017 Author Report Share Posted June 13, 2017 Just asking because the Lopresti is now installed now on my F... It is a thicker then my OEM and not quite flush on the sides. The 201 cowl being thicker explains this then. I guess on a 201 the Lopresti would be flush on the sides. Quote Link to comment Share on other sites More sharing options...
carusoam Posted June 13, 2017 Report Share Posted June 13, 2017 (edited) See if you can find Byron... @jetdriven When it comes to thickness and spacing, he put some effort into improving the worn areas around the hardware holding his 201’s cowling in place. Probably need to revive the thread... My F is faster than your 201 while you are at it... Best regards, -a- Edited June 13, 2017 by carusoam Quote Link to comment Share on other sites More sharing options...
75_M20F Posted June 13, 2017 Author Report Share Posted June 13, 2017 KS told me what I needed to know. 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted June 13, 2017 Report Share Posted June 13, 2017 He's got skills... -a- Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted June 13, 2017 Report Share Posted June 13, 2017 How big is the step aft of your new cowl? You might be able to fair it in with some filler if it isn't too large. Not a big deal to leave it as is, though, in terms of having an edge proud to the air stream, which would eventually fail the paint.Sent from my LG-US996 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Guest Posted June 13, 2017 Report Share Posted June 13, 2017 The step depth for the aluminum cowls of earlier models is shallower than for the fibreglass cowl of the J model. Clarence Quote Link to comment Share on other sites More sharing options...
75_M20F Posted June 13, 2017 Author Report Share Posted June 13, 2017 (edited) 7 hours ago, KSMooniac said: How big is the step aft of your new cowl? You might be able to fair it in with some filler if it isn't too large. Not a big deal to leave it as is, though, in terms of having an edge proud to the air stream, which would eventually fail the paint. Sent from my LG-US996 using Tapatalk It is about half the width of the cowling edge. It is streamlined with the wind so I don't see any drag issues. It's really very minor but I was surprised it wasn't flush. Otherwise it is looking stellar. Edited June 13, 2017 by Mooney_Mike 1 Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted June 13, 2017 Report Share Posted June 13, 2017 It does look great!Sent from my LG-US996 using Tapatalk Quote Link to comment Share on other sites More sharing options...
carusoam Posted June 13, 2017 Report Share Posted June 13, 2017 There have been many 'upgrades' using 201 cowls on older planes... There may be some insight about the same issue for the same reason. Thinking out loud... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
75_M20F Posted June 13, 2017 Author Report Share Posted June 13, 2017 9 hours ago, carusoam said: See if you can find Byron... @jetdriven When it comes to thickness and spacing, he put some effort into improving the worn areas around the hardware holding his 201’s cowling in place. Probably need to revive the thread... My F is faster than your 201 while you are at it... Best regards, -a- "My F is faster then your 201" now that would be fantastic fun. Where is that thread? Hahaha Quote Link to comment Share on other sites More sharing options...
Marauder Posted June 13, 2017 Report Share Posted June 13, 2017 1 hour ago, Mooney_Mike said: "My F is faster then your 201" now that would be fantastic fun. Where is that thread? Hahaha I hope you have good before and after numbers. I was always curious on the actual gain. As an faster F owner (I flight plan 150 but routinely see 152 KTAS), it would be interesting to see the actual gain. Also keep in mind there were other tweaks to the J over the years. I think the late model ones (post 1990) were 160+ machines. Quote Link to comment Share on other sites More sharing options...
75_M20F Posted June 13, 2017 Author Report Share Posted June 13, 2017 29 minutes ago, Marauder said: I hope you have good before and after numbers. I was always curious on the actual gain. As an faster F owner (I flight plan 150 but routinely see 152 KTAS), it would be interesting to see the actual gain. Also keep in mind there were other tweaks to the J over the years. I think the late model ones (post 1990) were 160+ machines. I need to get rid of all these antennas all over this thing. That alone is prob costing me quite a few knots. 1 Quote Link to comment Share on other sites More sharing options...
Marauder Posted June 13, 2017 Report Share Posted June 13, 2017 I need to get rid of all these antennas all over this thing. That alone is prob costing me quite a few knots. Some of those can go under a one piece belly and others can go in wing tip fairings. You having that done?Sent from my iPad using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
75_M20F Posted June 13, 2017 Author Report Share Posted June 13, 2017 1 hour ago, Marauder said: Some of those can go under a one piece belly and others can go in wing tip fairings. You having that done? Sent from my iPad using Tapatalk Pro Perhaps in a year or two on the belly mod, I have spent enough $ for right now at least. Quote Link to comment Share on other sites More sharing options...
AF M20J Posted June 19, 2017 Report Share Posted June 19, 2017 Hey @Marauder (or anyone) can you point me to the thread that details how to put the antennas in the wing tip fairings? Thx Quote Link to comment Share on other sites More sharing options...
rbridges Posted June 19, 2017 Report Share Posted June 19, 2017 Did you change from the stock windshield to a 201 style? Between that and the cowling, you're going to notice quite a speed bump. Quote Link to comment Share on other sites More sharing options...
carusoam Posted June 19, 2017 Report Share Posted June 19, 2017 AF, There is one MSC that built their name and reputation on updates and good ideas for older Mooneys... I would expect that Lasar would be the place to go to get the details and hardware that will be required. Have you seen the http://lasar.com/mods/ look for wing tip fairings with nav antenna... Best regards, -a- 1 Quote Link to comment Share on other sites More sharing options...
AF M20J Posted June 27, 2017 Report Share Posted June 27, 2017 Thanks @carusoam Quote Link to comment Share on other sites More sharing options...
