1524J Posted May 7, 2016 Report Posted May 7, 2016 This is old and many may have seen it, but thought I'd share just in case. After every flight, UPS pilots fill out a form, called a "gripe sheet," which tells mechanics about problems with the aircraft. The mechanics correct the problems; document their repairs on the form, and then pilots review the gripe sheets before the next flight. Never let it be said that ground crews lack a sense of humor. Here are some actual maintenance complaints submitted by UPS ' pilots (marked with a P) and the solutions recorded (marked with an S) by maintenance engineers. By the way, UPS is the only major airline that has never, ever, had an accident. P: Left inside main tire almost needs replacement. S: Almost replaced left inside main tire. P: Test flight OK, except auto-land very rough. S: Auto-land not installed on this aircraft. P: Something loose in cockpit S: Something tightened in cockpit P: Dead bugs on windshield. S: Live bugs on back-order. P: Autopilot in altitude-hold mode produces a 200 feet per minute descent S: Cannot reproduce problem on ground. P: Evidence of leak on right main landing gear. S: Evidence removed. P: DME volume unbelievably loud. S: DME volume set to more believable level. P: Friction locks cause throttle levers to stick. S: That's what friction locks are for. P: IFF inoperative in OFF mode. S: IFF always inoperative in OFF mode. P: Suspected crack in windshield. S: Suspect you're right P: Number 3 engine missing. S: Engine found on right wing after brief search. P: Aircraft handles funny. (I love this one!) S: Aircraft warned to: straighten up, fly right, and be serious. P: Target radar hums. S: Reprogrammed target radar with lyrics. P: Mouse in cockpit. S: Cat installed. P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer. S: Took hammer away from midget.
dlthig Posted May 7, 2016 Report Posted May 7, 2016 I've seen this list before. A lot of it is generic for many aircraft, but has some military specific items. When I started my military leave from UPS a couple of years ago I don't remember anything like this. Just the aircraft logbook for squaks and a sense of humor there wasn't appreciated.
Brandontwalker Posted May 7, 2016 Report Posted May 7, 2016 By the way, UPS has had at least one accident. A couple of years back a UPS plane crashed at KBHM while landing on the RNAV for RWY 18. Both pilots lost their lives. Night RNAV approaches are no longer allowed on RWY 18/36 as a result. Funny post, but factually inaccurate. Sent from my iPhone using Tapatalk
Jim Peace Posted May 7, 2016 Report Posted May 7, 2016 Don't forget the 747-400 that crashed in Dubai ...Flight 6......2 pilots killed..... And like DLTHIG wrote there is no sense of humor in that company.....
BDPetersen Posted May 7, 2016 Report Posted May 7, 2016 At NWA there was a cabin logbook in which cabin items were griped by the Lead Flight Attendant. One memorable write-up noting that the call chime used by the cockpit to get the f/a's attention was unreliable and low volume read "Captain's dong is soft and sometimes doesn't work at all." I believe it was repaired. 3
