I finally got the accu track installed.   It works as it should.  Also the ability for standard rate turns with the turn of a knob is nice.
Im happy with it so far.  It's pretty basic, but it follows the magenta line just fine.
  • 2 years later...
Welcome aboard, Moonet.
You can post a pic or two if you want.
Where are you located, if somebody wanted to stop by and pick it up?
