Weak Strobe
chrisk
I've got a 1981 M20K (231),  On my last flight it seems as if the left hand strobe is not as strong as the right hand strobe.  Has anyone else experienced this?  What are potential causes?  Bad bulb?  Bad power supply?
Link to comment
Share on other sites
Chris, It could be the power supply (probably a capacitor) or the bulb.  A new bulb is cheap enough.  Depending on the strobe system you have, you can also test the power supply by swapping sides (this assumes you have a power supply in each wing).  If you find out it is the power supply, send me a PM.
Link to comment
My left strobe went out. I just changed my 81 J to LED, so I have a power supply cheap!
I'm curious what sort of LED solution you went with.  I took a closer look at my strobes and they are to older style.  I believe SDi made them and it doesn't seem like bulbs are readily available. It's quite the contraption where the bulb, reflector, and fixture are all combined.  --In any case, I still have more work to isolate the issue to power supply or bulb.
Link to comment
Same thing happened on my 231 when i picked it up. Maxwell installed a refurbished power supply (due to pre buy inspect finding) but it never worked right. Installed a brand new wheels supply and haven't had an issue since.
Link to comment
