Releew Posted May 14, 2015 Report Posted May 14, 2015 Annual time and I have run into a problem that was not there on the previous inspection or last 50 hour. There is chafing (~1/16 deep) on the Passenger In-board Cowl Flap Hinge as well as the In-board Pilot side Cowling (~2" Right of the in-board hing) It is very apparent its being caused by the collection canister/muffler. My mechanic tried to raise the canister on the risers but there is very little adjustment, if any. I am trying to figure out exactly what's sagging and why all of a sudden. Possibly the motor mounts???? As always, any advice would be greatly appreciated. Thanks, Rick
Releew Posted May 14, 2015 Author Report Posted May 14, 2015 Haven't place the cowling back on. Will check first thing! Thanks!
jetdriven Posted May 14, 2015 Report Posted May 14, 2015 The lasar cowl kit helps but I ditched the non floating camloc receptacles and made a stopper block on the top cowl. Camloc receptacles are not designed to accept that kind of shear load. It wears out the holes in the cowl. Here's the result. A deadass 1/16 gap. A run into the ditch and total the airplane look still a 1/16" gap. 1
Releew Posted May 14, 2015 Author Report Posted May 14, 2015 Looks like it is the compression of the lower mounts. Thanks!!! Rick
Releew Posted May 23, 2015 Author Report Posted May 23, 2015 Which is the better mount? Lourds or Barry? Barry is on there now. Lourds mounts are less expensive but I want the best for the aircraft. Any experiences???? Rick
N201MKTurbo Posted May 23, 2015 Report Posted May 23, 2015 I've used both and I can't tell the difference. Usually Lord mounts are more then Berry. I buy whatever is cheaper.
Releew Posted May 23, 2015 Author Report Posted May 23, 2015 Thanks. I'm digging for a deeper explanation. Is one better based on longevity or vibration isolation? Rick.
Shadrach Posted May 23, 2015 Report Posted May 23, 2015 The lasar cowl kit helps but I ditched the non floating camloc receptacles and made a stopper block on the top cowl. Camloc receptacles are not designed to accept that kind of shear load. It wears out the holes in the cowl. Here's the result. A deadass 1/16 gap. A run into the ditch and total the airplane look still a 1/16" gap. image.jpg Byron would you mind elaborating on your install/mod. That looks rather precise compared to wha I often see. The F has no gap, because its an overlap, but it is easy to see the cowl moves even after it's fastened...
Releew Posted June 14, 2015 Author Report Posted June 14, 2015 Went with the Berry mounts. Installed today. The aircraft shows a noticeable improvement in flight. Less vibration, my left rolling tendency is gone and I feel it rotates easier off the ground. Before flight the spinner back-plate was aligned perfectly with the cowling. Upon landing it looked like it dropped ~.25". My APIA says perfectly normal...... I hope so! Thanks Rick
