larryb Posted April 16, 2015 Report Posted April 16, 2015 Hello: I'm looking to install a JPI 900 to replace all gauges in my 84 J model. I've been studying the Mooney IPC and the JPI install manual. My current source of confusion regards the fuel and oil pressure hose sizes. The JPI manual shows the transducers as 7/16" thread and -4 size fitting. Reading the Mooney IPC isn't clear on the hose sizes, but cross-referencing the pn's indicates they are -3 size. Does anybody know what the factory hose sizes and fittings are? The JPI manual specifies attaching the transducers to the firewall. The factory has the transducers clamped to the engine mount. I prefer the firewall, since I suspect there will be less vibration and possibly longer transducer life. Also, does anybody have a good source on the hoses and fittings I will need? Fuel hose oem: 912040-501 parker: 124F001-3CR-0290 oil hose oem: 912040-503 parker: 124F001-3CR-0170 Thanks, Larry Quote
jetdriven Posted April 16, 2015 Report Posted April 16, 2015 the fuel hose is a -3, both straight ends, and 29.0" long. Th oil is the same but 17.0" long. here is my quandry. Why have 40" extra of fluid hose under the cowl when u can extend the wiring and mount that fuel pressure sender close to the fuel injector servo? Also, use the 124J hoses. Same price but the fire sleeve is made onto the hose. Smaller OD, tighter bend raduis, and easier inspection. If its good enough for SpaceX rocket engines its god enough for me All my hoses came from PHT and they all fit exactly. Robert E. Williams President Precision Hose Technology, Inc 918-835-3660 Robert@aircrafthose.com www.aircrafthose.com Quote
larryb Posted April 16, 2015 Author Report Posted April 16, 2015 HI Byron: Thanks for the info. Does that mean the fittings on the engine side of these hoses is 3/8 x 24? Is it possible to get a hose with 3/8 x 24 on one end and 7/16 x 20 on the other? Larry Quote
carusoam Posted April 16, 2015 Report Posted April 16, 2015 Find the thread for additional JPI 900 installation/sensor challenges. It might be helpful... Anyone know where Bob Belvil's JPI install thread is? Best regards, -a- Quote
jetdriven Posted April 16, 2015 Report Posted April 16, 2015 HI Byron: Thanks for the info. Does that mean the fittings on the engine side of these hoses is 3/8 x 24? Is it possible to get a hose with 3/8 x 24 on one end and 7/16 x 20 on the other? Larry Those are standard AN thread sizes for -3 and -4 hose. I'm pretty sure they an make them with whatever size fitting you need. Some of those senders are NPT and you should be able to make a hose with a female NPT on one end. There are also straight, 45 and 90 degree hose ends too. Quote
