schule Posted January 1, 2015 Report Share Posted January 1, 2015 I have tried the search function with no real success, so here is the question: It appears the UL listed on planes with TKS is around 100 pounds less than a similar one without it, does the UL adjustment to the POH/W&B assume a full TKS tank? Or do you have to also add in the weight of TKS onboard after? If not then during summer flying can you gain back the 55ish pounds of TKS not carried? This winter's weather and my hankering for high altitude turbo flying, has me thinking some bad thoughts like a FIKI Bravo. Quote Link to comment Share on other sites More sharing options...
Will W Posted January 1, 2015 Report Share Posted January 1, 2015 The weight and ballance does include a full tks tank. The chart spells out "TKS-FLUID TANKS (Full 6.0 Gal.)" in the W&B / equipment list section 6. At least in the Ovation POH for my serial number specific one. Quote Link to comment Share on other sites More sharing options...
schule Posted January 1, 2015 Author Report Share Posted January 1, 2015 Thanks. Do Bravo's with TKS have a similar W&B as the Ovation? I would expect the system is pretty much the same. Quote Link to comment Share on other sites More sharing options...
Mcstealth Posted January 1, 2015 Report Share Posted January 1, 2015 I believe a full tank of TKS fluid is 30lbs or so, and the equipment is 70 lbs. I have always heard the 100lbs also. Â or is it the other way around? Quote Link to comment Share on other sites More sharing options...
Will W Posted January 1, 2015 Report Share Posted January 1, 2015 Is your Bravo known icing? That would make a difference if your bravo is not. It's the same body and system will be the same. It weighs 9.2 lbs per gallon and figure 6.0 gallons (6.3 goes in the tank, 6.0 usable). Quote Link to comment Share on other sites More sharing options...
carusoam Posted January 2, 2015 Report Share Posted January 2, 2015 50+ lbs that far back from the center of lift sounds important to know the effects on W&B from full to empty to me... How does one know how full the tank is at any time? Does it use a sight glass or floating sensor? Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Will W Posted January 2, 2015 Report Share Posted January 2, 2015 An indicator is on the panel. Â It tells you exactly how many gallons are onboard. 1 Quote Link to comment Share on other sites More sharing options...
M016576 Posted January 2, 2015 Report Share Posted January 2, 2015 50+ lbs that far back from the center of lift sounds important to know the effects on W&B from full to empty to me... How does one know how full the tank is at any time? Does it use a sight glass or floating sensor? Best regards, -a- It has a sensor. And I agree- the W&B for my install has an empty tank-> I add the weight of the fluid as applicable, just like fuel. Quote Link to comment Share on other sites More sharing options...
schule Posted January 2, 2015 Author Report Share Posted January 2, 2015 Thanks all. It looks like each install may have a different W&B starting point. 850# UL on a Bravo with another 55# of TKS would be of limited utility for a XC of any length with 2 on board. Maybe the difference is another of non-FIKI vs FIKI differences. Quote Link to comment Share on other sites More sharing options...
carusoam Posted January 2, 2015 Report Share Posted January 2, 2015 make sure you are getting all the numbers correct... the O has a UL that is over 1,000 LBs... it has Charley weights installed behind the back seats. these CWs get swapped out when equipment upgrades get swapped in. The sole purpose of the CW is to control the B by adding W back there. it would be better to have more ice protection and less CWs... Go Long Body, -a- Quote Link to comment Share on other sites More sharing options...
Cruiser Posted January 2, 2015 Report Share Posted January 2, 2015 my FIKI TKS system was installed per STC SA00306W1 (no fluid) weight 39.80 # Quote Link to comment Share on other sites More sharing options...
