1980 M20K
Anyone have a stock number on the Gascolator gaskets?
I also needed to get some exhaust flange gaskets but do not have a illustrated parts catalog for the engine. Continental TSIO-360-LB1
Any help is always greatly appreciated.
V/R
TMcD
1980 M20K
This is what pops up when you do a search on Aircraft Spruce for exhaust gaskets, Continental:
http://www.aircraftspruce.com/catalog/eppages/rapcoexhaustgas.php?clickkey=76731
Gasket, gascolator turns this up:
http://www.aircraftspruce.com/catalog/eppages/gascolatergasket05-11187-91.php?clickkey=31380
Or, you can order from the manufacturer....
Thanks... Did that first and both didn't look like the ones i have changed in the past, so, i thought they were too generic and wouldn't work.
I am trying not to take the belly off to get a picture and model number of the gascolator...  And that exhaust gasket should be the same for all the TSIO-360, but the RAPCO just didn't look right due to the compression ring.
I will keep digging...
Thanks!
TMcD
The exhaust gasket is a TCM 630365 or Superior SA630365. Spruce now stocks the complete line of Superior parts and will have them - you'll need two per cylinder. The blow proof ones look intriguing but I don't know if they are interchangeable.
Your Gascolator gaskets will depend on which one you have as Mooney used a few. Mine uses an Airight. Suggest you call LASAR or SWATA being closer to you and they will be able to send you a set or tell you what to get.
FYI, My AiRight uses 2 0-rings, the larger one is a fluorocarbon M83248/1-137 and the smaller one is a MS29512-5. To my knowledge, they're not available from Spruce but from many other outlets - just google the part #'s.
