Brock Posted April 29, 2014 Report Posted April 29, 2014 You're running too high a power setting in my opinion (85%). TIT is OK. Your chances of making TBO at that setting... not good. Don, what do you recommend for cruise power? I have been running 30/2300, but with the high cost of OH want to maximize engine life. Quote
Bravoman Posted April 30, 2014 Author Report Posted April 30, 2014 Don, what do you recommend for cruise power? I have been running 30/2300, but with the high cost of OH want to maximize engine life. I too run at about 30/22. I figure this about 75%. I am also curious as to Don's thoughts about this setting. Quote
FlyDave Posted April 30, 2014 Report Posted April 30, 2014 I found that my engine runs much smoother at 2400 than 2200. Does your engine run as smooth at 2200 as at 2400? I typically cruise at 2400/26" at around 15.5 gph. Quote
carusoam Posted April 30, 2014 Report Posted April 30, 2014 http://donkaye.com/donkaye.com/Welcome.html In case you want direct contact.... Best regards, -a- Quote
Bravoman Posted May 1, 2014 Author Report Posted May 1, 2014 I found that my engine runs much smoother at 2400 than 2200. Does your engine run as smooth at 2200 as at 2400? I typically cruise at 2400/26" at around 15.5 gph. Not so much smoother but quieter. You will note that 22 is the lowest allowable rpm setting. I have always likened lower rpm settings in cruise to be analogous to driving a car in the higher gears(i.e. lower rpms) on the highway. The engine works less hard and the gas consumption is less. At 30/22 I am typically burning 15.5 to 16 gph as well. Regards, Frank Quote
