nels Posted July 29, 2013 Report Posted July 29, 2013 Does anybody know how to pull the rear seat back out of a mid 60's E model? I need to remove it to get the plastic side panel back in.
Bob_Belville Posted July 29, 2013 Report Posted July 29, 2013 I had mine ('66E) in and out several times last years redoing the interior. Then the avionics shop removed it again for new panel. You should have no problem with the bottom seat, it lifts up from the back and the front is held down by clips behind the screwed on panel behind the back seat passenger's heels. The back rest is held by 4 bolts on the ends. The 2 upper ones will be simple enough, the bottom ones are a little mean to get out, take note of washers and spacers and that the outside ends of the seatbelts are on the same bolt. If you can get at the snap on clip it might help to remove belts first. You'll need sockets and wrenches. I suppose 7/16" or 3/8", I don't remember, there's nothing metric on our old Mooneys. After you've removed the bolts it's a matter of maneuvering the seat out without the allowing the upper clips to scratch the side panels. It's a tight fit. 1
47U Posted July 29, 2013 Report Posted July 29, 2013 Here's the frustrating area Bob is referring to...
mooney389 Posted July 29, 2013 Report Posted July 29, 2013 If you can slide your side panel in by pulling back on the seat, maybe two people, it would be much easier than taking the back rest out.
scottfromiowa Posted July 29, 2013 Report Posted July 29, 2013 If you can slide your side panel in by pulling back on the seat, maybe two people, it would be much easier than taking the back rest out. +1. This is what I did. Worth the effort! Good luck on your project
nels Posted July 30, 2013 Author Report Posted July 30, 2013 +1. This is what I did. Worth the effort! Good luck on your project I'll be at the airport tomorrow or maybe the next day and I will take another look at it possibly pulling the side of the cushion back but I have a feeling the seat back will need to come out. I'll let you know how it turns out. Thanks for the input so far.
