I had recalled seeing a thread on this, but I couldn't find it. What is the brand everyone is using for the brush on product. And are you happy with it that vs the glue down rolled product, TY
I have only used brush on wingwalk.  Are you repainting your plane or contemplating stripping what you have off and replacing ?
I had a leak on the upper side of the wing, so the first third of the material has already come off. I was thinking of taking it all off and then putting the brush on product on
45 minutes ago, N201MKTurbo said:
Use Hurculiner truck bed liner. It is exactly the same stuff as Ultimate Wing Walk. But costs 1/3 the price and is easier to get.
https://herculiner.com
You want a quart of original roll on. It is enough to do your wing walk twice.
Ok, what do you mean by a "quart of the original roll on"?
There is "original" and "professional"   in gallons and quarts.
Replacing the glue on stuff
18 minutes ago, NewMoon said:
And if you have a leak down the road, can you scrap this stuff off?
Yes you can. I have done it. After you remove the screws or panels, use a small paint brush to dab some new stuff into the low spots and hit it with a roller. It will look good as new.
Did you see these previous discussions on addressing the leak under the wing walk?
  • 2 weeks later...
It is 5 years ago that you guys helped fix the leaking cover bolt. It's be dry ever since and so have the tanks. Thanks for that. Last month, I have decided to remove the 40-year old wing walk completely and replace it with a 3M skateboard anti-skid. This is the state of affairs with the paint remover ...
