Yetti Posted October 30, 2025 Report Posted October 30, 2025 Brilliance https://www.ebay.com/itm/297495591929?_skw=kx+155+kx+155+kx+155&itmmeta=01K8VEVS5KD72WTA5JE6NE2KXB&hash=item45441e7bf9:g:Aj4AAOSwkbpl19Zw&itmprp=enc%3AAQAKAAAA0FkggFvd1GGDu0w3yXCmi1eTV2FwYlTKR6b6AqRAHndmJxrm5GaV9rcVe0VZcOJVag5SiFxr1g%2FdGbNFdYlgJFZbpk%2FCOZUPzOMMrZS0El4fCaKPpacrq4JK6EjtHGv4uob%2FVRq2L1JeP64EW7VLebbcKXFsFXpkfYf2qKLBVbrueeGbB%2FQVkS2LcrNzPzzF63%2FxRelVgXRPR6eK9Z3orV4s5p6OIhh%2B%2BNkDd10k73kSiZH2E4lMYdc1PPD6%2BVzi8zMKhTOO3D4scf1EWAFFvbY%3D|tkp%3ABk9SR7CT7-7GZg
N201MKTurbo Posted October 30, 2025 Report Posted October 30, 2025 Wow, $750 for about $50 of non PMA parts. I should have thought of that. 1
N201MKTurbo Posted October 30, 2025 Report Posted October 30, 2025 2 hours ago, Yetti said: Brilliance https://www.ebay.com/itm/297495591929?_skw=kx+155+kx+155+kx+155&itmmeta=01K8VEVS5KD72WTA5JE6NE2KXB&hash=item45441e7bf9:g:Aj4AAOSwkbpl19Zw&itmprp=enc%3AAQAKAAAA0FkggFvd1GGDu0w3yXCmi1eTV2FwYlTKR6b6AqRAHndmJxrm5GaV9rcVe0VZcOJVag5SiFxr1g%2FdGbNFdYlgJFZbpk%2FCOZUPzOMMrZS0El4fCaKPpacrq4JK6EjtHGv4uob%2FVRq2L1JeP64EW7VLebbcKXFsFXpkfYf2qKLBVbrueeGbB%2FQVkS2LcrNzPzzF63%2FxRelVgXRPR6eK9Z3orV4s5p6OIhh%2B%2BNkDd10k73kSiZH2E4lMYdc1PPD6%2BVzi8zMKhTOO3D4scf1EWAFFvbY%3D|tkp%3ABk9SR7CT7-7GZg Ya know, if you delete the question mark and everything after it, the link will still work, but Google won’t get any ad money when people click it. https://www.ebay.com/itm/297495591929
EricJ Posted October 30, 2025 Report Posted October 30, 2025 12 minutes ago, N201MKTurbo said: Wow, $750 for about $50 of non PMA parts. I should have thought of that. That was my thought as well. Somebody saw an opportunity and jumped on it. 1
Pinecone Posted October 31, 2025 Report Posted October 31, 2025 And exactly how does this get signed off in an certified airplane?
EricJ Posted October 31, 2025 Report Posted October 31, 2025 3 hours ago, Pinecone said: And exactly how does this get signed off in an certified airplane? Same way anything else does. 1
dkkim73 Posted October 31, 2025 Report Posted October 31, 2025 I've been struck how useful it is to have displays replaced in old components. E.g. BMW electroluminescent displays from the 80's-00's. New life in old components! Retro look! Makes sense for the old King gear. Now I just need a nixie tube watch...
NotarPilot Posted October 31, 2025 Report Posted October 31, 2025 9 hours ago, Pinecone said: And exactly how does this get signed off in an certified airplane? As an owner produced part?
AJ88V Posted November 1, 2025 Report Posted November 1, 2025 Trouble is the yellow tag, or lack thereof. Of course, if nothing bad ever happens, nobody would know. Here's a vid about how to install. A little more than just plug and play, but nothing difficult.
Yetti Posted November 5, 2025 Author Report Posted November 5, 2025 On 10/31/2025 at 8:44 AM, Pinecone said: And exactly how does this get signed off in an certified airplane? Down the rabbit hole of TSO you go. My understanding is the radios are agreed to by the manufacture to a certain specification.... ie the TSO. With the new display the radio will still comply with the TSO. I guess you could also go down the FCC regs of who can work on a Transceiver. But I think Aviation Radios are not really under the FCC regs.
EricJ Posted November 5, 2025 Report Posted November 5, 2025 27 minutes ago, Yetti said: Down the rabbit hole of TSO you go. My understanding is the radios are agreed to by the manufacture to a certain specification.... ie the TSO. With the new display the radio will still comply with the TSO. I guess you could also go down the FCC regs of who can work on a Transceiver. But I think Aviation Radios are not really under the FCC regs. They are under the FCC, but you only need a GROL (general radio operator's license) if you do something that affects the transmitted signal. Changing the display has nothing to do with the radio transmitter, so it's not an issue. Any A&P can install or work on a radio (as long as it doesn't affect the transmitted signal), just like any other component in the aircraft. Really the only thing an A&P can't touch are instruments (other than marking) and propellers (other than servicing, basic dressing and finishing). An A&P can "supervise" somebody else doing the display installation by inspection afterward, and that is best accomplished with prior coordination. 1
